n5 cylinder clearance issue
aaronac1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaronac1 Quote  Post ReplyReply Direct Link To This Post Topic: n5 cylinder clearance issue
    Posted: 20 Sep 2015 at 7:24pm
Im having a hard time getting my clearance closed up to cut beans. This is my second season running this combine. It acts like its stuck. I had a little trouble last year getting it closed up but I finally did. Has anyone run into this before and what else can I do. Beans should be ready this weekend
Wd-45 D-17s4 170 185 190xt 7045 8070
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 8:05pm
Had a similar problem with my R52. One of the pins was seized in the mechanism at the top of the concave area. Once I figured that out and freed it up was no problem to adjust it completely closed. Not sure how similar the N5 is to a 52
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaronac1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 8:35pm
What it does move you have to crank harder than heck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 8:39pm
You can do beans at 1/2" clearance or a little more. Shift it into HIGH gear at 650 RPM minimum and go combine. It will loosen up some as you use it. They do move hard sometimes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaronac1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 9:06pm
I cant get it under 1" right now.im not a small man by any means and I have a hard time moving it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2015 at 9:59pm
You shouldn't have been over 3/4" for corn anyway. I'll bet the rock door is jammed against the concave from opening it too far. Not there, so it's just a guess.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2015 at 1:20am
Once had one that wouldn't move either and broke the adjusting arm where it goes thru the side of the combine. It was a new to me N5 and first time trying to adjust it. ended up missing some parts that moves the concave on the left side of the concave. Might try a prybar in their and see if it moves. My guess is someone worked on mine before we bought it and didn't put all the parts back in there.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2015 at 12:14pm
7/8 jam nut on the bounce bolts on each end of the rock door. The bounce bolts have a square 1/2 head. Loosen the bolts then set your clearance. Retighten the bolts. Hope this helps. I reset them for corn and for beans. 5/8 - 3/4 for corn at 350 rpm low range and 1/2 for beans at 700 rpm high range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aaronac1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2015 at 7:30pm
Last year was my first season running the in 5 and it was hard to adjust then but I did get it set. So do I need to open the rock door to see whats going on?
