Four-cylinder in-line Ford |
Unit3
Topic: Four-cylinder in-line FordPosted: 12 hours 2 minutes ago at 8:06pm |
Have a four-cylinder in-line Ford in a Joy air compressor. It runs great for the man in town, but when I get it out here to the farm, it will not run. Can a coil be good and then bad and then good and then bad. I would think once they go bad they’re bad. This will be the third time in a week. I’ve taken it to him. The man who works on it is absolutely incredible. You may not doubt his abilities. He can rebuild your Briggs & Stratton or your CAT C 15 engines. I cannot allow you to doubt his work. We have just got an intermittent problem on this engine. Can a coil be good one second bad the next and then go back to being good?
Darwin W. Kurtz
Joined: 06 Apr 2010 Location: Westphalia, KS Points: 5099 |
Posted: 11 hours 51 minutes ago at 8:17pm |
I had an International 560 tractor that I could never start. Would have the mechanic come and that thing would start. Finally, after a couple times he says let's put an inline fuel filter that they sell at wal mart on this just to be safe. We put one of those in and I never had trouble getting it to run again.
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10038 |
Posted: 10 hours 55 minutes ago at 9:13pm |
Is there fuel in the tank and is the shut off turned on?
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6090 |
Posted: 5 hours 44 minutes ago at 2:24am |
Things don't happen for no reason. SOMETHING is changing. Is the Ford an overhead valve industrial 134, 174 or 192?
Les Kerf
Posted: 2 hours 34 minutes ago at 5:34am |
Not likely but anything is possible. Since you hinted at it, but did not clearly state, I am guessing that the engine is losing spark? Is it a breaker point ignition, or an 'electronic' type? I would be inclined to look for poor connectivity; I have encountered faulty ignitions switches on several occasions. Also, the corrosion monsters never sleep
Posted: 1 hour 12 minutes ago at 6:56am |
If the key switch also powers the starter engagement, the key switch might not be providing power to the coil/points when cranking. It has happened before.
