D21 series I |
Dwight from Orlando
Bronze Level Joined: 11 Sep 2009 Location: Orlando FL. Points: 59 |
Posted: 07 Dec 2023 at 3:15pm |
My D21 has set for a few years. And I went ahead and changed all the fluids and the fuel in the tank. Put in new fuel filters, put in new batteries.
And tried to start it. It turns over fine. But I discovered a small leak in the fuel line leading to the injector pump. replace that sleve. I pumped the pump quite a few times but it's not starting doesn't seem to be getting fuel. What might I have to do to make sure the fuel is getting into the injector pump and lines to the injectors. Thanks. Edited by Dwight from Orlando - 07 Dec 2023 at 3:18pm |
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4783 |
Usually a Roosa pump like this gets the plungers stuck when sitting in old fuel. Typically they need properly disassemble and cleaned up and recalibrated and tested. Modern fuel does not sit and age well.
Dwight from Orlando
It's a STANADYNE pump.Does that maKe a difference?
Edited by Dwight from Orlando - 07 Dec 2023 at 4:26pm |
AllisFreak MN
Orange Level Access Joined: 07 Dec 2009 Location: Minnesota Points: 1505 |
Stanadyne / Roosa - same thing.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8031 |
i think it says, Roossamaster by Stanadyne.....
if it's been a few years there's a good chance it has biodiesel in it. THAT IS BAD FOR SETTING!! Edited by SteveM C/IL - 07 Dec 2023 at 10:50pm |
Orange Level Access Joined: 12 Sep 2009 Points: 19586 |
Does the electric shut off "click" when you turn the key on/off ?? A trained ear can hear that device on the pump to know if it is functioning or not.
Dwight from Orlando
Yes, it does click when you turn it on and when you turn it off.Does that mean anything about the pump?Thank's Dwight
Edited by Dwight from Orlando - 08 Dec 2023 at 11:16am |
Dwight from Orlando
Should I take the nut loose on the number 6 cylinder injector, Which is the furthest from the pump and continue to try to pump the priming pump to see if I can get fuel that far until it starts leaking out?
Yeah. See if it will start on 5 cylinders first and then shut it off and tighten up the nut.
Dwight from Orlando
Now I'm trying to put my pump back on, but it will go as far as being 3/8. inch from the housing cannot find anything that could possibly be causing it. Has anyone had this problem? I left the shaft in the tractor, but greased it up real well.Seems like the key on the side of the cone inside the pump is a larger than the key way in the inside of the shaft. Could they have replaced that part inside the pump when they rebuild it? Thanks Dwight
d17brown
Orange Level Joined: 11 Sep 2009 Location: farley iowa Points: 1668 |
take, the side inspection plate off of the pump. do you have fuel running out
phil
Was a recent post about installing pump on a similar tractor. Think the approach was to remove front gear cover at pump to help handle install.
Dwight from Orlando
Thank you, Steve very much, that looks like the problem. I'll attempt it that way, but it sure had me stumped at the time. Appreciate the help thanks.
55allis
Orange Level Joined: 30 Jun 2020 Location: Southwest IA Points: 549 |
DONT force it on!!!!!!
Did the shaft come out of the pump? If it did it will only go on in one position. I made the mistake of thinking it was right and than went to start it and the pump pretty much exploded the guts… Had to find another pump which are very hard to come by.. |
Check out Wendell's post on D21
Dwight from Orlando
55 it sounds like the magnets had moved out of position.was the throttle wired back?
Edited by Dwight from Orlando - 25 Dec 2023 at 11:08am |
I hope you had marks lined up in timing window on #1 compression stroke before pulling pump and then never turned engine before install attempt. Otherwise your going to have many more questions.
Dwight from Orlando
No I did not lineup the timing window. I had done it a few years ago and put it right back together. And it slipped right on and worked fine. So I didn't think about that this time. And also the guy that rebuilt my pump came out to help me lineup the splines and keyway in the shaft. And we couldn't get it so he had me turn the tractor over. Sounds like what you're saying not to do I did.. The tractor engine is turned and the and the lines weren't lined up in the injector pump. So, what am I looking forward to now? If you could tell me please thanks Dwight.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3246 |
I would loosen #1 injector by removing the hold down bolts, spray some soapy water around the foam seal - turn the engine over til it bubbles then contintue to the corroect timing mark on the front pulley BTDC - this asures you are on compression - then look through the #1 hole in the head of the pump after removing the banjo bolt and line and turn the pum until you see the round hole start to show in the hole where the bolt came out. This will be approx #1 where the mark should have been on the gov ring. pump turns the same way as the engine. Now install the pump after reinstalling everything and leaving a line loose at one injector to bleed. IF you have no marks you will have to guess at the timing. When you nail the throttle and it 'pings' it is too advanced - if sluggish and no 'crack' at throttle up - too slow. If it runs hot afterward - too advanced - too much smoke - too slow. Country boy fix when the specs ain't there and you don't want to have it redone correctly.
55allis
Should be timing marks on the gears if you pull the cover off…
Tbran's advice will get you there. If it starts and runs you could then check the timing window marks VS degrees on balancer to see how close you are. You will have to know how many degrees advanced the timing is for that engine/pump. It's just easier to do things in order.
Dwight from Orlando
Thanks everybody I'll have to try it.
D-21 timing is 34 degrees BTDC, clearly marked on the crankshaft pulley. At this number the two marks inside the pump window should be aligned.
Lets hope the rubber inside the balancer ring is in good shape and hasn't slipped throwing off the timing marks.
Dwight from Orlando
Page 1
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78014 |
so whats the UPDATE, Dwight ?
SOOOO....did you get it figured out?
Dwight from Orlando
Sorry it took so long to respond but I had to get my slab and footer built for my building. I was gonna use my D21 with a front end loader to move dirt. But I didn't make it in time. So I have now gotten back to working on the tractor and have removed the front gear and was able to get the injector pump on. I've set the Timeing on the crank to 34° before top dead center. And in the viewing window on the injector pump, I lined up to the 2 lines. The key in the injector Is at just below 3 o'clock so I looked at the shaft thats coming out of the tractor and I moved the tractor engine around until it came to 34° before top dead center, and then Looked at at the shaft in the spline was 180° off, so I turned it to just below 3 o'clock. Just like the pump key. that's how I figured my timing without removing and using soap bubbles on the number one that it must be in the compression stroke. Because the alignment with the pump and the key inside the pump at 3 o'clock. So I'm hoping that is right. Do you guys have any comments on that ?
Dwight from Orlando
Thanks for all the help.
Edited by Dwight from Orlando - 22 Mar 2024 at 4:19pm |
Dwight from Orlando
When a series I Allis D21 loses fluid from the trans and diff, does it most often come from the Trans front seal? Thanks Dwight
