valve lifters
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Topic: valve lifters
    Posted: 19 May 2022 at 9:34am
I have a NOS camshaft for a WD/WD45, but can't find a source for new or rebuilt lifters at a reasonable price. ( $58 each).  I have several sets of used lifters in good condition.  Would it be safe to use a set of the used lifters on the new cam?  I have overhauled several W series engines, but have always kept the cam and lifters together, and made sure the lifters went back on the same lobes each time I installed the cam, but this is a new situation and I need expert advice.  Thanks.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 11:34am
Hi Ted , A good up todate valve gringer will do this for for you , or find a good machine shop near by .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 9:40pm
Put the used ones in, they will out last both of us.                    MACK
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2022 at 9:42pm
I had a similar question a while back with my WD. After asking the question, I ended up getting the cam reground anyways and then I resurfaced the lifters with an attachment on my valve grinder. Just like you, I found that new lifters are not a cheap date.
There is some question about how deep these were hardened from the factory. Nobody has a solid answer, but they seem to be hardened deep enough to take at least some material off and still be left with a hardened surface. I actually have yet to finish putting my engine back together.
