lift cylinder packing?
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Topic: lift cylinder packing?
    Posted: 20 Apr 2021 at 11:44am
Is the packing for a CA better quality from an Agco dealer than a cheaper aftermarket set? Agco is about double the price, but if it's a better product then I don't mind. Just want the leak to go away!
CA Tractor
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 12:01pm
I would suspect they are both made in the same place with different packaging.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 1:25pm
I've seen the cheap ones and AGCO both...I would go with AGCO...
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 7:06am
thanks
CA Tractor
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 8:52am
When you say "packing" what exactly is that?  I have heard that term used for repairing cylinders, but never really understood it.  I thought lift arm cylinders required new seals, etc. to repair leaks.  Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 8:55am
In my parts book for my 14 it looks like O rings are used in the lift cylinder.  I never been in one so I'm not exactly sure tho.
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 8:57am
New Packing/Seals they are the same thing.
CA Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2021 at 9:57am
The lift cylinders on my WD45 are leaking some fluid.  A neighbor mentioned, he took the nut on the end off, wrapped some graphite packing rope around the ram, then tightened the nut back on and this stopped the leaking for him on his '45.  Does that make any sense?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 1:07pm
Here is a site with some graphite rope packing that appears to be for cylinders.  Anyone have experience with this stuff?  https://www.grainger.com/category/pumps/pump-accessories/compression-packing-seals?altTerms=Rope+Packing&filters=altTerms&ef_id=EAIaIQobChMIi-WD0suP8AIVsmpvBB0GxQa5EAAYAiAAEgJRPvD_BwE:G:s&s_kwcid=AL!2966!3!496591133932!b!!g!!&gucid=N:N:PS:Paid:GGL:CSM-2296:9JMEDM:20500731&gclid=EAIaIQobChMIi-WD0suP8AIVsmpvBB0GxQa5EAAYAiAAEgJRPvD_BwE&gclsrc=aw.ds
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 4:38pm
some cylinders use a square rope type packing, but that is normally low pressure.. "MOST" single acting cylinders 50 years ago used what is call CHEVRON VEE packing... and yes, you tighten up the nut to FLARE OUT the VEE and it seals on the walls of the cylinder and the rod both... If it is worn and needs more CRUNCH, you might be able to add a rope ring, but normally the old VEE is HARD and time to replace.
Im sure ALLIS sells packing for twice what others do. If you buy from a REPUTABLE dealer, you can probably get it for half price..There are a lot of guys that sell VEE packing for cylinders..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 4:41pm
If you have a few minutes, this is worth reading......
and toward the end are a couple links to quality generic VEE packing.
Edited by steve(ill) - 22 Apr 2021 at 4:42pm
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2021 at 5:00pm
I used Baum Hyds. for my packing on my D12. They were a 1/3 of the cost and worked great!
