Grandfathers CA
 Post Reply Post Reply Page  <1 910111213>
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 9:15am
Thus, with new wires, plugs, rotor and cap, is this the magneto coil that is cutting out at high temp or the magneto condenser? Connections are tight. Maybe replace both??
Your right on track... Could be either, or both..
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 4:20pm
Just ordered both from DJ's..... I am hoping this resolves the issue. I think I will change one at a time to see which is the culprit offender!!
Edited by CA13414 - 02 Sep 2024 at 4:40pm
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 4:59pm
Just for info, CAs with engine prior to CE149840 came with magnetos, those from CE149840 and on came with distributors.  My 1952 CA13092 has a distributor.  I have no idea whether that's original or not.  Would be interesting to know where CE149840 broke in but didn't see that on the AGCO site.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 9:03pm
Interesting!! Let me pull the serial number form our "farmed in" CA. Definitely it is a magneto and I will bet you are right..... Our farmed in CA is an earlier number than the number of my grandfathers CA.
As well, as I type, I do remember that our family CA does have a distributor. This would make sense.
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 11:48am
It has been a while since I have posted on our CA. Not much has happened this winter with our little friend in the shed for the winter.
However, this spring, I am planning to not only change out magneto coil and condenser, but will replace the clutch and pressure plate. When I was pulling a large load of sand with the blade in 1st gear there was a bit of slippage.
While there are a few different ones available, not sure which I should order..... an 8.5" or 9" and if rigid or spring loaded. Also not yet sure yet if I will need a pilot bearing or bushing.
Any other recommendations while we have it split in half?
Thanks, Dan
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 12:46pm
Just a note,are you sure which clutch is slipping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2025 at 3:09pm
Great question. I had not thought about which one, engine or final drive. What would be the best way to determine which one is slipping?
Dan
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 2:16pm
if the pot is engaged if the foot clutch slipes it will stop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2025 at 2:21pm
Awesome!! That makes perfect sense. :-)
Will try and see which one it is.
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 4:32pm
Finally pulled the CA out to check which clutch was slipping.
Put the drain plug back in the carburetor bowl and opened the gas line. Gotta love it started right up and ran perfectly.
Once out of the shed, put it in 1st gear and with PTO/hydraulic pump engaged and let the engine clutch out with full brakes and when it slipped, the PTO was turning. Thus, it is the final drive hand clutch that is slipping and not the engine clutch. Appreciate "Sparky's" and "tadams" advice on how to determine which one was the issue. Would have been an "adventure" to change out the engine clutch when it was not the problem.
Many thanks!!!
Edited by CA13414 - 18 Apr 2025 at 4:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 4:45pm
Now to adjust the final drive clutch and see if that fixes the slipping. If that doesn't fix the issue, expect I will need to take apart the differential. I have looked for new "disk plates" for the final drive clutch and can not find any.
Maybe someone knows a source?
The other thing I need to do is to change out the magneto coil and capacitor. Hope this will fix the issue I had last summer of losing "spark" when the engine is hot. Not sure why but I would lose spark to cylinder #2. A new distributor cap, rotor, plugs and wires did not fix the issue. I suspect this is due to a bad capacitor, but while I am in there will change the magneto coil as well.
Edited by CA13414 - 18 Apr 2025 at 6:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 7:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 7:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 7:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 7:19am
Awesome Steve. Those are awesome links. Thank you!
Do you have an idea where I can get new clutch plate for this if needed. I looked on AGCO and all the typical parts store. Also a general Google search without luck.
If nothing, do I just need get the straight shaft from the farm and remove the clutch?
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 8:27am
I think i would call Sandy Lake and talk to them to see if they can still get the clutch plates. They did have them 5 years ago. ... Your right, i dont see much advertised on GOOGLE search... Might also have someone REBUILD the plates with new linings. Not sure who still does that..
Solid shaft is always an option if you never use the clutch... or have no other options.. IT is possible the plates are not overly worn, but RUST and CRUD are your major problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 1:26pm
If you take it apart when you put it back together use locktight on the bolt that hold the hand clutch together. I have ran into this poblem and I tore it apart and tightened the bolt and no it's slipping again. I didn't use any lcktight on the bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 10:04pm
Thank you! Will do!
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 6:03pm
Called Brenda at Sandy Lake Implement in Sandy Lake, PA (724)376-2489.
Brenda was super awesome. A refurbished hand clutch plate, new springs and throwout bearing are on the way!! Just need to send back my clutch plate as a "core!" Core charge is ~$500. :')
Makes me realize, that old hand clutch on the farm is worth a bit rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 6:39pm
Also Lon Saeger was awesome about getting some shims to tighten up the final drive. This is where the clunking occurred when driving the tractor. I was able to move the final drive 4-5 mm in and out and recreate the "clunk!"
Edited by CA13414 - 22 Apr 2025 at 6:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 6:44pm
Originally posted by CA13414 CA13414 wrote:
While driving down the road could hear a clunking. This was also notable with a slight left and right turn. I think the final drive shaft needs adjusting but wanted to ask other and see what you think.
Here is a link to a video of the noise from the final drive.
Just to bring this back up in the thread. Here is my prior post on the noise from the final drive which I think is due to the slack in the final drive.
Edited by CA13414 - 22 Apr 2025 at 6:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 6:35pm
To correct my previous comment about adding shims. I was visiting with Lon, and he indicated that removing shims is what I need to do to tighten up the bull pinion shaft and the wheel axle shaft, not add shims.
Hope to get all this done here in these next weeks.
Edited by CA13414 - 23 Apr 2025 at 8:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 8:50am
Just received the rebuilt clutch plate, springs and throwout bearing for the final drive from Sandy Lake Implement. They look awesome. Now to find the time/weekend to get the work done.
Edited by CA13414 - 16 Jun 2025 at 8:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 8:42pm
As previously noted, cylinders 2 and 3 quit working after the engine warms up. This was at an idle and full throttle. 2 was worse than 3, and there is no spark on #2 to the fingertip when touching the wire!! :-)
Thus as a follow up.... I had previously replaced the spark plugs, the wires, distributor, cap and rotor without fixing the problem. This past Thursday I replaced magneto coil and condenser which did the trick…… “thus far!!”
I’m putting our little “Orange Dude” to work this weekend. That’ll be the test!
Edited by CA13414 - 16 Jun 2025 at 8:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 9:11pm
This past week, we took the CA to my friends Dads shop to take the CA apart to replace the final drive clutch. As well to work on his C10 Chevy as noted below. All went well. The rebuild clutch plate and springs from Sandy Lake were installed after cleaning up the pieces. It was clear the disk was slipping with wear on the pad.
Two issues we noted. First the springs were worn and/or lost some of their compression. Here you can see the new spring on the left which has almost a 1/4" greater length.
As well, the spring cover, secondary pressure plate with the springs, lined plate and pressure plate was intact and the surfaces looked great. However this as a unit was not bolted to the brake drum with 5 of the 6 bolts missing and one sheered off.
Figure AC129 of the shop manual has a great exploded figure which details this.
In retrospect, this was like this when we replaced the final drive seals last summer. I just did not recognize this as an issue until we noticed the slack upon reassembly last week. My friends Dad, said that doesn't look right and he was correct.
Regardless, we pulled it back apart and removed the sheered bolt, tapped out the threaded brake drum and put it back together with LockTight (as previously suggested). We used the vice in combination with tightening each Allen bolt. This made a huge difference in the slack.
All said and done, the hand clutch for the final drive worked awesome when reassembled. There is no slipping of the engine clutch or final drive hand clutch. Could feel the hand clutch "pull-over-the-top" as it disengaged and engaged. With reengaging I will need to be careful since it has quite a "grab." I expect if I do not let it slip a bit, I will shear off the bolts again.
It took about 4.5 hours in total, we drove it up on the trailer and headed home after working in the shop getting ready to rebuild the Chevy C10. Was an awesome day.
Edited by CA13414 - 17 Jun 2025 at 6:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2025 at 10:09pm
Here is our next project. From the farm we have two Chevy pickups my Dad used over the years that have been in the trees for over 20-30 years.
My bother is rebuilding Dad's 1970 Chevy 1500 Short Box fleet side. We have a 350, 4 bolt main, engine which after taking off the pan, all is well and turns without an issue.
We will tear this down and plan for a 0.030 overbore, a stroker crank shaft with new rods and pistons, and double hump heads. With this he will have a great engine for pulling his camper, trailer or anything.
Would love fuel injection to add efficiency, but wow that is about 2K+
The other Chevy is a 1972 C10 that my friend is rebuilding..... will post a few pictures as it happens.
Edited by CA13414 - 17 Jun 2025 at 6:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2025 at 5:45pm
Good evening!
I changed the engine oil and filter before starting today.
She ran awesome for the first 30-40 min, then started missing once again. I let it cool down and once again would fire on all 4. Still was able to get the work done, however, just was intermittently missing. Now it was ~90 degrees out, but water temp was only 170 degree's.
I could not see a spark, and only intermittently feel a spark when touching the #3 wire.
I think I will try and replace the points next, unless other have ideas.
Not sure if that could be why this would happen when hot. As per the other thread "CA erratic spark" that is active on the forum, will look at the cam lobes and check for wear.
Dan
Post Options Post Options   Thanks (1) Thanks(1)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2025 at 10:12pm
Finally put together the CA "Red Fender" light.
We had sandblasted it last summer and when I opened it up this past week, it was rusted out. Thus, I ordered a new "Bulb Socket" and BA15S 12v 2700K LED lights. Removed the old socket and drilled into the old bracket and attached the new bulb socket. I did need to add a ground wire due to all the rust on the inside and could not make electrical contact to the bolt that attaches to the fender. This despite using the Dremel and grinding down to metal. Somewhere an electrical break. Thus, two wires. Will need to ensure good contact of this wire to the fender when installed with a crimped loop-end that runs back to the new socket.
Here is the final finished with two wires.
And powered up.
Edited by CA13414 - 30 Jun 2025 at 11:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 2:12pm
Today, I changed the point set on the magneto. Was an easy change.
When snapping the magneto there was not spark. Took off the distributor cover and simply touched the coil spring contact and no spark with any snap of the magneto. Disconnected the ground wire for the kill switch from the point set, and still no spark off the coil contact.
Ideas to what is next? I double checked and it doesn't look like a wire is fractured or grounding out the coil.
Will try and get the magneto manual and read for options.
Dan
Edited by CA13414 - 19 Jul 2025 at 2:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 2:20pm
sounds like a bad condener or coil... you say the point is clean and not grounded out.
Edited by steve(ill) - 19 Jul 2025 at 2:22pm
This page was generated in 0.300 seconds.
