Wd45 hand clutch seal
500592 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 hand clutch seal
    Posted: 12 Aug 2026 at 6:38am
Is it possible to change the seal where the hand clutch lever shaft enters the casting or does that require the frame rail to come off?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 9:03am
One of my neighbors just did that and he removed the frame rail.
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 10:21am
I just did mine and I cannot see anyway to do it without taking the frame rail off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 500592 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 6:36pm
Thanks for the confirmation it will make a good winter project. It is only slowly dropping at the moment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2026 at 6:47pm
Put a good bottle jack right under the PTO box and put slight pressure on it. Remove the right side frame and reinstall.
