Wd45 hand clutch seal |
500592
Topic: Wd45 hand clutch sealPosted: 12 Aug 2026 at 6:38am |
Is it possible to change the seal where the hand clutch lever shaft enters the casting or does that require the frame rail to come off?
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 4016 |
Posted: 12 Aug 2026 at 9:03am |
One of my neighbors just did that and he removed the frame rail.
albatros_3
Joined: 16 Apr 2012 Location: SE Michigan Points: 452 |
Posted: 12 Aug 2026 at 10:21am |
I just did mine and I cannot see anyway to do it without taking the frame rail off.
500592
Posted: 12 Aug 2026 at 6:36pm |
Thanks for the confirmation it will make a good winter project. It is only slowly dropping at the moment
DrAllis
Posted: 12 Aug 2026 at 6:47pm |
Put a good bottle jack right under the PTO box and put slight pressure on it. Remove the right side frame and reinstall.
