AC-220 pulling |
Kevin210
Topic: AC-220 pullingPosted: 02 Aug 2026 at 7:22pm |
I hope I'm not doing anything wrong here,but here goes.
First off I am a proud DAD...The 220 is up and running and doing pretty good,We still have to get the weight distrubution figured out,but all in good time. There is a video of my daughter pulling on you tube. It is her tractor btw. dad and her fiance did most the work. Her first video is on you tube,Allis Chalmers 220 13,000lb 8mph farm stock. Just looking for advice on anything about it. I have a 210 that I have pulled for years so I am somewhat familar with 220 ,any advice appreiciated on the 220. |
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1866 |
Posted: 02 Aug 2026 at 7:34pm |
You need to also put this request in the pulling forum.
Edited by sparky - 04 Aug 2026 at 7:59am |
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2384 |
Posted: 02 Aug 2026 at 7:44pm |
Now it was not farm stock, but back in the 70's who pulled a modified 220 and he mopped up everybody, I think he was out of southern Indiana.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3806 |
Posted: 03 Aug 2026 at 1:36am |
Congratulations Kevin210 on your daughter’s 220 pull. She is sitting on the edge of its seat! The 220 sounds great. Great pull !!
Here’s a weblink of what I think/hope is her pull video? https://m.youtube.com/shorts/1MnwJ7by1wU |
DrAllis
Posted: 03 Aug 2026 at 6:23am |
5th gear @ 3,000 RPM is pretty close to 9 mph actual tire speed. The engine had a lot left in it on that track, I think. One front weight moved to the rear may have added 20 more ft of pull distance ??
Buddy2366
Posted: 03 Aug 2026 at 6:42am |
Love the flame coming out the stack on that 220!
DrAllis
Posted: 03 Aug 2026 at 7:19am |
Nothing a little water injection wouldn't take care of !!
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1055 |
Posted: 03 Aug 2026 at 9:18am |
I think the guy from back in the 1970's was Al Arnold. His 220 was unstoppable.
Kevin210
Posted: 03 Aug 2026 at 9:38am |
Yes AC7060IL that is her,she placed 2nd there.They went to Philpot,Ky this weekend and had a good time there,she pulled against some cut tires and water injection in one class and her fiance did really good on his IH 1466.Don't know if she has posted those yet or not..They're having fun and that's all that matters.
Buddy2366
Posted: 03 Aug 2026 at 7:27pm |
Dr Allis, I had no idea water injection was as simple to do as you described.
Edited by Buddy2366 - 03 Aug 2026 at 7:28pm |
DrAllis
Posted: 03 Aug 2026 at 8:28pm |
I've made several kits over the decades for various HP levels of turbo diesels. I always had the trigger switch on the throttle linkage under the hood so it would turn on when you just got to full throttle. When your pull is over, cutting back on the throttle shuts it off. Waiting to go the last inch on the throttle until you're down the track 200 ft or so works best. Removing the air filter and spraying into the air stream headed for the turbo gives the windshield washer fluid time to turn to a fine mist. Often one could see fire out the exhaust like this 210 and when the switch was tripped, the fire immediately went away. It's really important to get the volume/amount correct or bad things can happen.
NEVER green
Posted: 05 Aug 2026 at 3:43pm |
Great pull! How many cc's of fuel??
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
Kevin210
Posted: 05 Aug 2026 at 8:41pm |
Has all the diesel shop could get out it,
which is what I told them. |
