8070 and 3000 plow |
Post Reply ![]() |
Page 12> |
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 606 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Nov 2022 at 8:23pm |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5219 |
Hope you make a video of her tearing up some ground. She looks ready to work.
My nephew got some good video. Can you upload a video file to the forum?
1984 80780
I bet your nephew can figure it out. I think you put it on YouTube and then post the link here?
Thanks ac720man. Thats what he's working on. We should have it by monday
1984 80780
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8715 |
Looking forward to seeing it
Darrel |
Bad news on the 8070. Started it today and had a tapping in the bottom end.
Think I might have spun a rod bearing. Going to get the pan off in the next couple days and see whats going on |
1984 80780
BlueBandit17 ![]() Bronze Level ![]() ![]() Joined: 04 Nov 2022 Location: Falcon, NC Points: 4 |
8070NC's nephew here - I finally got the video uploaded. Bear with me, I am new to the forum and Youtube uploading as well! Allis Chalmers 8070 and 3000 Plow: Let me know if the link does not work. |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8706 |
Welcome to the forum nephew. Video worked good.
Sorry to hear of the noise 8070
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34306 |
Just posting a cropped pic of 8070 with 3000 plow, so it is on the page. Sorry to hear that the 8070 has noise of trouble... Hope nothing serious. ![]() |
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
Thank you for the copmpliments fellows. Its a labor of love but from a practical standpoint its cheaper and simpler with this equipment than newer
1984 80780
Gleanermanl2 ![]() Bronze Level ![]() ![]() Joined: 29 Sep 2013 Location: Kansas Points: 21 |
Hey I found a brother!uploads/10292/Resized_IMG_20200726_170840358.jpeg
Awesome. Somehow my plow is different than those plows. The front wheel on my plow is directly outside the tractor wheel so i cant run dual wheels. Looks like the tube the hitch is attached to om my plow is shorter
1984 80780
Ive got a full set of coulters but they are the rubber spring type and they have all come apart and i havent decided how to fix them
1984 80780
Anybody got any suggestions
1984 80780
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5094 |
great vid, looks bouncy! Sorry to hear about the engine issue! Dang the luck man!
I was bouncy Ed. I had methonol put in the tired that morning and they put too much air in them. I didnt take time to let them down cause it would need to jack it up to get the valve stems to thr top. Ill do it while its in the shop to see about the bearings. Ill let you know what i find
1984 80780
I don't think these plows were designed to be pulled with duals on the tractor. These are pretty old plows and I think they probably came out in the late 60's. Mine is a 3000 plow as well. I cant hardly turn right at all with the duals on but in a big field I can pull it with large headlands. Next time I pull it I will yank the duals off. As far as the colters go. I have no recommendation on repair of them. Mine are not the rubber mounted type. I would suggest finding a scrap plow and just robbing some others off.
Ive got lathes snd milling machines so I thought id make the coulters into a spring type ive got too much to do thats more important. Maybe a dead of winter project
1984 80780
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
I have the same 7 furrow 3000 plow but with hydraulic resets. Hope to try it on my 220 fwd . I think they are a very rare plow.
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12155 |
7 bottoms with a 220? Wow.
7 bottoms with a 220? Wow. Slow and steady wins the race ! |
My plow is hydraulic reset.
Dangdest thing i ever saw Ive seen places in the field where a bottom had tripped and reset but i never felt it in the tractor |
1984 80780
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21834 |
Back in "the day", the D-21 was touted as a 7-bottom tractor and the mighty 220 Land Handler was 8-bottoms.
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2296 |
Had a neighbor buy new 220 with 8 bottom reset plow. used for a few years, then got a 440 with 3 point, used plow with that for several years.
DCAC ![]() Orange Level ![]() Joined: 20 Oct 2018 Location: east central SD Points: 511 |
I have a 7 bottom toggle trip and one with hydraulic reset. My grandpa bought the toggle trip plow new and we used to pull it with a 210.
Did you figure out what was going on in the engine
I believe its fine. I pulled the #2 rod cap and the bearing is fine. Im going to put a set of rod bearings in while im in it.
Ill know for sure next week when the bearings get here |
1984 80780
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 812 |
I would replace the harmonic balancer also.
Post Reply ![]() |
Page 12> |
