1200 Cultivator wing lock, How?
joepro91 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joepro91 Quote  Post ReplyReply Direct Link To This Post Topic: 1200 Cultivator wing lock, How?
    Posted: 13 May 2020 at 8:34am
Guys, how to the wings lock up for transport on my new to me 1200 field cultivator.
( it has hydraulic fold wings ).
Thanks
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:54am
I used a come-a-long on mine, a chain on each wing will work.
Also removed the rod end pin of the cylinder to let the wing go all the way down and rest on the main frame, but that is a pretty good "tug" to get up again.
Do not let it rest on cylinder hose fittings, they will break!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:04am
Depends on the age and width, but some of them had a special U-bolt with hairpin locks that was used as a safety lock. It was pretty crude and probably got lost or broken.
Edited by DrAllis - 13 May 2020 at 9:05am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 9:15am
This is on a 1350. Don't know if it's the same as yours. Have to use a come along to take the pressure off the pin to remove or lock it in.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 10:27am
My 1200 goes over center but it's only 18-1/2 feet wide.
Wink
I am a Russian Bot
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 10:30am
Mine had the crosspin setup on it. VERY hard to get out and in, always had to push mine over with the loader at home ---at the other farm I had to struggle with a loadbinder to get enough slack to drive the pin out.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 9:05am
I'll take a picture when I get to the farm today, if I can remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 2:24pm
Here's a pic of mine. 18' 1200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 2:52pm
BINGO !!!
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 10:20am
Were these used on the 16 -1/2 foot also?
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 10:31am
If it is the same age, I'd say yes. Changes were made over the years on some items and that particular design was kinda cheesey at best.
