8070 power shift woes.
orangeman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman69 Quote  Post ReplyReply Direct Link To This Post Topic: 8070 power shift woes.
    Posted: 30 Sep 2018 at 8:21pm
my son was pulling a vertical till and he lost all gears except for 2nd,looks like oil is coming out of the bottom of the housing where theres a inspection hole. hi or low range doesn't matter. no reverse just 2nd. any ideas would be greatly appreciated..
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 10:25pm
Nut come off front planetary carrier or pulled end off of it. A complete rebuild.        MACK
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 2:48am
Is this common for the power shift trans?
Wasn't there a better fix to prevent it from happening again? (like weld the nut?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:29am
No good reason for it to happen. Have saw them tear nut lock off, have saw more than one pull hub into just behind nut with nut still locked on.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:36am
When I assemble one, I use Loctite on the nut and then stake it with a center punch really good one time at the keyway. If I ever have to take it back apart I which I never have) I'll split the nut with a sharp chisel.
Edited by DrAllis - 01 Oct 2018 at 7:23am
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 7:49am
We had the exact same issue on our 8050 this spring. We're lucky enough to have an AC mechanic with all the specialty tools and knowledge. We supplied all the labor. Cost less than $500 for parts but many hours of free labor.
Leon B Mo
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 8:18am
I'm afraid that Mack is correct on this problem. You can confirm this by taking the valve body,behind the batteries,off of the tractor and use a pry bar under the front clutch pack to see if it's loose. I like to have the tractor in a position where it can be split before I even take the valve body off. Duals off and rear wheels moved out are a plus for this job. Fuel out too.
This page was generated in 0.099 seconds.
