Header weight
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: Header weight
    Posted: 28 Dec 2017 at 12:38pm
What would a 93 830 hugger corn head weigh ? Thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2017 at 6:10pm
5400 pounds with sheet metal dividers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 6:43am
Thanks Doc, would that be too much head for a R-50 ?
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 6:56am
It is the perfect head.  I have one on my R52 which is the first year they were made, so I have a different cab than an R50 only.  It is the best head for the combine in my opinion, you can keep the machine full without going fast and I found I get a lot cleaner sample that way from mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 7:03am
A twelve row would be fine on an R-50 if you could pick it up. The harvester is made for so much thru-put per hr. With 12 rows, you'd go half the speed of a 6 row. Your throat lift cylinder size may play a part in picking up an 8 row. I thought there was a standard diameter cylinder and an optional larger diameter on an R-50.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2017 at 8:23am
ya Doc your right as usual, agco parts shows 2.5" and a 3" cylinder for a 50, Thanks again guys, Dave
This page was generated in 0.273 seconds.
