185 Running Rough
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Topic: 185 Running Rough
    Posted: 22 Dec 2015 at 11:41am
I bled the injectors and all but the one on #2 cylinder bled. I'm not getting any fuel out of that line. What can be the issue?
-Slim
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 11:54am
yes, if no fuel is going to the injector, it won't fire that cylinder, thus rough running. Now, being a Roosa pump, it's uncommon for them to lose one cylinder. Check the line carefully, and make sure it came loose from the injector when you loosened the nut. Sometimes those stay sealed in the injector and have to wiggle the line to pop it loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:37pm
I saw one once when the opposing cylinder had the tip split. Why, don't know, maybe Ed can tell us.   MACK
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2015 at 5:52am
If the problem is truly as described, I'd guess the #6 injector tip may be stuck open or split.
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2015 at 11:17am
So I was able to get the #2 injector to bleed. Still running rough though. What kind of wrench do I need to get the injectors out? They have like a zillion points.
-Slim
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2015 at 11:46am
sounds like a 12 point socket is what you'll need, just regular tools. Either 5/16 or 3/8. The bolts are 5/16.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2015 at 6:44pm
Pull all 6 send them to injpumped when the come back you will be another satisfyed cust
Edited by bradley6874 - 25 Dec 2015 at 6:45pm
This page was generated in 0.219 seconds.
