Later d17 saved from fence row
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 8:57pm
Not logically. All the other bearings look fine. An oil pump failure (there is none) would have ALL bearings damaged, not one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 9:11pm
It doesn't float on top of the oil. It's submerged. Been too long....I think it has an air pocket to keep it raised but it can sink if oil is low or steep hill etc... Either way it's always in the oil so that's not what ruined your bearing.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 10:35pm
That was what I was thinking but I wanted to make sure.
I will see if I can get it to drain and get it patched up. Probably with have to have it soldered (looks like a visit to the local blacksmith).
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 9:27am
55Allis, how is this fence row D17 patient? Did you locate some good used sleeves/pistons/rings/etc? Or did you go with a new rebuild kit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 10:36pm
I’m planning on a complete new rebuild, figured by the time I’m done anyway it won’t cost much more.
The crank is the problem right now, it’s possibly gone too far to have it ground but the guy doing it could possibly get it built up again.
Currently waiting for a phone call from him next week (possibly and hopefully) for a definite answer.
I did get the head fully rebuilt (new valves, guides, and freshened up seats).
Also got the rims for the WD primed and painted so I can put the 16.9s on the D17, at least then I can say it’s on the start to go together..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 11:56pm
There is zero reason for him to "build up" a crank journal when there are hundreds of used cranks laying around in salvage yards. Bearings of minus .040" should be available for that crank.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 6:05am
Things like this happen when you have a mechanic that really isn't familiar with Allis Chalmers engines. Unnecessary expensive repairs get done without anyone realizing there is a lot less expensive fix.
A friend of mine has a construction business. His screening plant had an AC 125 (B, C, CA) engine on it. It started putting coolant in the oil. His mechanic, who is a very good heavy equipment mechanic, told him to get another head because the head was cracked. He gave me the old head. I took the core plugs out of it and they were rusted out (not unusual). There was nothing else wrong with the head.
Sometimes paying a mechanic that is familiar with the brand you are working on is worth the extra cost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 1:26pm
Not going to build up, just confirmed that the rod bearings are std and the crank was turned .020 under… Bet that really hammered/knocked when it did run!!
Guy can get me a .020/.020 under crank for $700. Is there any known cheaper options?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 3:37pm
Has the crank been newly machined to .020/.020 ? If it has, the price is in the ballpark
Make sure it is a crankshaft for a G-226 and not a W-226. When I look at replacement crankshafts, some say their crankshaft fits a WD45, D-17, 170 and 175. The G-226 were in the D-17, 170 and 175, but not in the WD45 (which was a W-226). They use different size bearings.
Edited by WF owner - 29 Dec 2025 at 3:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 9:02pm
Thanks for the warning!!
Yes pretty sure it was freshly done.
Sure don’t take long to fill it with green paper …
I was really hoping this one would be saveable but we win some and lose some.
I had a slight hope of finding a junk gleaner around here but I guess the scrap price is too good for that.
I have been going off the casting number (229022) on the crank so hopefully I get the right one.
The spun rod is bad too so I’m wondering if it’s the same as a wd/wd45?
I think I have some of those on hand…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 6:19pm
Does anyone know of a place to get the clutch disc relined?
The clutch it’s self isn’t too bad, just the pads getting worn down.
I’d rather fix it now before it wears into the rivets.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 6:37am
Doo a google search for clutch repair or reline. You should find some locally. There are a few near me. Sounth Bend Clutch and Fort Wayne clutch.
If you're doing the clutch you'll need to have the flywheel ground and stepped and also have the pressure plate rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 9:24pm
Clutch measures at 5/16” thick, measuring both pads and the disk its self.
Not sure what the specs are supposed to be..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 11:22am
Talked to local Agco dealer and they can get a Hy-capacity overhaul kit (part number Hcrrp915151) for $770.
I can get a kit through jensales from Reliance for $626 with shipping paid.
Which brand is better?
I know others most likely has experience with both.
Also asked about the clutch, they have 3 options, a 4 pad, heavy duty 6 pad, and a solid woven disc. They have all 3 on hand and also the pressure plate.
I don’t want to put crap back in this tractor, I want it to last so give your honest opinion.
Thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 9:16pm
Set the new hood and grill on it today and put the rear tires on.
Still waiting on the crank, hopefully it comes next week.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2026 at 10:22pm
Got the front end adapted, wasn’t as bad as I thought it was going to be.
Cut the rear pivot point off and welded a 4”by 1 1/2” by 1/4” thick steel to space it out. Surprisingly that’s all it needed.
Also built up the front pivot shaft. So now there’s hardly any slope in the pivot system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2026 at 11:07pm
Got the brakes free’d up, surprisingly they are very tight, hardly any slop.
The clutch on the other hand is very sloppy, that might be the next fix on the list…
Does the clutch rod have a clevis on the pedal side? Someone broke/ welded it up very ugly like and it affects the clutch movement so it’s gotta be repaired.
Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 3:12pm
Talked to the machine shop that’s working on my block and he is thinking it’s going to need the block bored and sleeved where the O-ring seat due to rust pits.
It had anti freeze in it before I pulled it apart so I didn’t think much about that.
Whats everyone else’s thoughts?
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 5:28pm
Clutch pedal side does not have a clevis. Rod is angled and slips in from the inside. Mine was worn so I installed a brass bushing. Also installed a new bushing at the clutch pedal pivot point. Nice and snug now.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 6:45pm
Installed a lot of sleeves in some pretty questionable G-226 blocks using RTV silicone and have never had one come back even decades after the OH.
Edited by DrAllis - 23 Jan 2026 at 6:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2026 at 10:27pm
I was wondering if anyone tried that…
I think I’ll take my chances with the RVT silicone.
Thanks for recommending that!!
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2026 at 12:07am
I have done a few lowers on small cam Cummins, they had a habit of wearing a groove where the o rings seated. I used an epoxy product, make sure it is clean and you have to sand it down to smooth after it cures. Some of them took more than one application. With pitting it may be easier to use silicone.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 11:30pm
Thanks for the advice!!
Should I get new rod bolts?
The old ones look fine but machine shop thought I should replace due to to being apart more than twice.
They look very pricey…
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 12:56am
Whether your rod bolts are good, bad or indifferent you will think about them every time you run it because of your machine shop. I am not familiar with these engines, maybe they do need new rod bolts occasionally. They may have been stretched(overtorqued) last time it was apart or they may have been replaced. I don't know, and without knowing the last person to work on it you don't either. You do know they put standard bearings on a .020" crank. If you reuse the old ones you should at least measure them for stretch, just my opinion.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 4:17am
I have never replaced rod bolts on G-226 engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 11 minutes ago at 11:46pm
Will check for stretch on the rod bolts.
Does anyone have any measurements for the dry air filter clamp? Mines missing and I’m wanting to make a new one.
If it’s anything close to my 262 diesel it looks pretty simple.
Waiting to hear back from local machine shop, he was going to magnaflux the block for cracks. After doing some measurements he thinks the O-rings on the sleeves should seal ( think he got a bit excited too fast).
Been calling around for an overhaul kit and they all seem to be Reliance kits, only seems to be them or A&I (which probably is Reliance too). A&I is plumb high compared to Reliance. Any opinions?
Trying to keep it down on cost (which isn’t workin) but have a quality machine.
