parking brake 190
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: parking brake 190
    Posted: 05 May 2019 at 10:57am
any body ever fix  a non locking  parking brake on a 190  ?   HOW'd  you do  it ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 11:54am
If the brake lock does not work, it usually need to be freed up and lubricated. It also won't work if the spring is missing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 1:29pm
Its a interesting setup, the spring plays a big part of it , if it jumps out of lock the brake pawls need replaced
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 3:10pm
You can fix them sometimes by taking the piece off the end of the arm that locks into the teeth and putting a new edge on it with a grinder. Also sometimes they need the roll pin thru the handle on the shaft replaced.
Edited by DanWi - 06 May 2019 at 3:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 5:19pm
New ratchet teeth and a new pawl and a good spring and lube on the pivot area, they work great.  I saw one pawl installed BACKWARDS one time by someone who didn't know what they were doing. The same mistake could be done with the ratchets....they only work one way.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 6:35pm
Be thankful it's a 190, our 180 park brake set-up leaves ALOT to be desired. That engineer needed to be strung up IMO. What was wrong with the D series "clam" looking wedge system??
