WD hand cultch removal
19F150 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19F150 Quote  Post ReplyReply Direct Link To This Post Topic: WD hand cultch removal
    Posted: 06 Jun 2026 at 4:00pm
How do you remove hand cultch assembly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2026 at 6:18pm
Battery box has to be removed and then the tractor split apart about 8 inches right there. Hand clutch comes up and out the hole directly underneath the battery box.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2026 at 6:23pm
Page 34 in Part 1 of the Allis WD Service Manual gives a good explanation.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19F150 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2026 at 9:52pm
how do you get the handclutch housing apart from the transmison
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2026 at 10:03pm
Remove three 1/2" bolts on each side of the torque housing probably covered in dirt/grease. Remove two side frames bolts at the rear of each side frame. Brake pedal rods and springs disconnect. Steering wheel post disconnect from the transmission shift cover. PTO push/pull lever remove. Traction Booster signal linkage remove. Hand clutch clevis pin remove. That's about it I think. Roll the rear end away from the front. Use jacking under the PTO box. Use long redi-bolt thru the side frames ears to keep things under control. Why are you removing the hand clutch ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19F150 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2026 at 10:25pm
have all bolts removed and toque tube still won't come  off  from transmission
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2026 at 10:50pm
Have you got the PTO shaft removed from the tractor ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19F150 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2026 at 7:16am
PTO shaft is off.  torque moved about 1/4 inch is all
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2026 at 7:20am
Hand clutch released?? or still locked in ? The bottle jack under the PTO box might have to be raised or lowered just a tick. You might be on a bind.
Edited by DrAllis - 08 Jun 2026 at 7:22am
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2026 at 8:44am
is nt their a bolt inside the trans
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2026 at 9:38pm
As Dr Allis Says, Neewd to support the middle of the tractor.
