R76 Gleaner accelerator roll drive
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Topic: R76 Gleaner accelerator roll drive
    Posted: 19 Oct 2022 at 6:46am
I have an r76 that we put new drive gears on before beans and the gears are worn out already Anyone have an ideas Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 6:54am
Are the rollers in time?                        MACK
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 7:54am
Timing would be the first and only thing to come to my mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 8:10am
Never done one that new but, I do remember loosening the three bolts on each accelerator roll bearing flanges and positioning the roll shafts such that the gear lash wasn't tight, but also wasn't wide/loose. If you have had a failure of teeth, I'd imagine those shafts have been spread apart and the lash may be pretty sloppy, which could lead to early failures.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 9:27pm
Those teeth are very hard,they take thousands of hours wear,the only time i see them fail is if something goes through the rollers,like a piece of steel or stone,and then a tooth or two will be sheared. Otherwise maybe your rollers aren’t timed and are fouling causing damage.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2022 at 5:29am
Check timing first. Then gear lash. Could be a bent shaft but you can see that in the gear lash also. Could also be a bearing. Had a 62 one time that had a key way messed up.
This page was generated in 0.172 seconds.
