|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| D17 lift power in pounds? |
| Post Reply   |
| Hunt4Allis   Orange Level   Joined: 13 Mar 2018 Location: Ohio Points: 1172 |  Post Options  Thanks(0)  Quote  Reply  Topic: D17 lift power in pounds? Posted: 18 Jun 2021 at 9:22am |
   Hi fellas, Anyone know what a series1 rear arms should be able to lift? Also what is the hydraulic oil level supposed to be on dipstick- near gear shifter? Thanks Matt Edited by Hunt4Allis - 18 Jun 2021 at 9:23am | |
| Hunt4Allis   Orange Level   Joined: 13 Mar 2018 Location: Ohio Points: 1172 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jun 2021 at 6:31pm |
   Pimples here the question I'm asking is in reference to whether or not a d-17 can lift a 4x whether or not a d-17 can lift a 4x5 round bale approximately 800 lb that is situated right against the lift arms so as close to the tractor as it can be of course with a bale spear and two points below to assist
| Hunt4Allis   Orange Level   Joined: 13 Mar 2018 Location: Ohio Points: 1172 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jun 2021 at 6:33pm |
   The question I'm asking is in reference to whether or not a  d-17 can lift a 4x5 round bale approximately 800 lb that is situated right against the lift arms so as close to the tractor as it can be, of course with a bale spear and two points below to assist? No weight on the front, I'm sure it's capable but I'm wondering what the maximum lift capacity is? Edited by Hunt4Allis - 18 Jun 2021 at 6:34pm | |
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88476 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jun 2021 at 7:21pm |
   I would think a D17 could lift 1000 pounds if the load is kept close to the hitch point.
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88476 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jun 2021 at 7:25pm |
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22135 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jun 2021 at 7:47pm |
The lifting potential is directly related to how healthy your pump is !!   A very healthy pump should unload at 3700 psi. An old dirty and worn pump might be as low as 2500 psi, about 30% less. The internal lift arm cylinder is smaller in diameter than a series 3 tractor, again affecting lifting power. A diesel chassis has more front end weight than a gasser. A wide front has more weight on the nose than a NFront end.
 Edited by DrAllis - 19 Jun 2021 at 6:04am | |
| allisbred   Orange Level Access   Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jun 2021 at 9:42pm |
   Just adding to what has been said. With a working pump there should be no issue. Your tractor will most likely be a little light on the front and would benefit with a few weights. Our first round bale moving tractor was a series 4 with wide front and a rear mover. Just want to point out how dangerous those rear movers are in the dark. My father backed over a black calf that was in the feeder when setting a bale in, not long after we heard of a boy that was killed the same way. Father was one of our customers, it was a tough time. We switched to a front end loader around 1980 after those accidents.
| HudCo   Orange Level     Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3946 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Jun 2021 at 10:53pm |
   so how much does a two or three bottom roll over plow weight? handles them just fine hanging out there
| Hunt4Allis   Orange Level   Joined: 13 Mar 2018 Location: Ohio Points: 1172 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Jun 2021 at 7:23am |
   Right ok. I know there's alot of variables but I just wanted to know if it was feasible... WF on mine, rig is almost touching pto shaft. We will see. Thanks guys | |
| BillinAlberta   Silver Level     Joined: 12 Sep 2009 Location: Saskatchewan Points: 357 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Jun 2021 at 8:00am |
   Yes it can .I can pick up 5x5 bales easily at 1200 lbs but it has a front end loader out front for weight.Usually carry 1 in front and 1 behind.
| Hunt4Allis   Orange Level   Joined: 13 Mar 2018 Location: Ohio Points: 1172 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Jun 2021 at 3:25pm |
   It worked perfectly! Got them all moved in short time up on dry hill in pasture. It couldn't have worked any better, not pretty but from a used pile of parts and some welding/ fabrication it all worked out nicely. Thanks fellas     Edited by Hunt4Allis - 19 Jun 2021 at 3:27pm | |
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88476 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Jun 2021 at 3:52pm |
   Thats a very HANDY looking rear lift !!
| Hunt4Allis   Orange Level   Joined: 13 Mar 2018 Location: Ohio Points: 1172 |  Post Options  Thanks(0)  Quote  Reply  Posted: 19 Jun 2021 at 4:29pm |
   I can use it as pictured or remove spear and use as a pallet lift, remove forks and add a ball in middle to go get firewood with my trailer in our back woods, also built a pig pole with lifting eye that's adjustable along the length of pole that I welded up from square stock and it attaches to top link   | |
| DaveSB   Silver Level     Joined: 04 Aug 2012 Location: mocksville, nc Points: 243 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Jun 2021 at 2:23pm |
   Great job on the bale mover,I like how you made it. I knew the D17 would work, my neighbor moves them with a D10, I know much smaller tractor,  but it works fine for him.   Thanks for the pictures, enjoyed them. | |
     1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
| Hunt4Allis   Orange Level   Joined: 13 Mar 2018 Location: Ohio Points: 1172 |  Post Options  Thanks(0)  Quote  Reply  Posted: 20 Jun 2021 at 2:49pm |
   I feel like the pictures were owed to everybody who gave me insight on how to build this with ideas, I've been thinking and gathering parts for a long while to do this one!
| HudCo   Orange Level     Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3946 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Jun 2021 at 9:38pm |
   thosepallet forksare allways handy
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
