D17 lift capacity
dink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dink Quote  Post ReplyReply Direct Link To This Post Topic: D17 lift capacity
    Posted: 11 Aug 2019 at 1:27pm
I'm trying to find the 3 point arm lift capacity of a D17. I am looking at a no till drill that weighs around 2500lbs.
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 1:33pm
What series is you D17?
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 1:38pm
dink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dink Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 3:06pm
Probably a series I.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 5:51pm
So, you have an after-market 3-point hitch, which won't lift as much as a factory 3-point on a series 4 tractor.
dink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dink Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 7:35pm
yes
john(MI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 8:34pm
If you have a Saginaw three point, it will lift as much as a factory.  It mounts the same as a factory does, and it's as heavy duty as a factory one, possibly more.
As far as lift capacity, I don't think a D17 will lift that much weight.  If it does, you'll need to add some weight to the front end.
There is no information on that number in my data book.
Edited by john(MI) - 11 Aug 2019 at 8:47pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 9:12pm
A drill sets back of the tractor right much,I can't see a D17handling one that
weighs 2500lb.
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 10:47pm
I responded in the other thread... I've had some 2000+ lb loads close to the face on my 3-point... and based on how it handled that load, a 2500lb grain drill would not be manageable on a Series 1, even with lots of counterweight. It would be able to lift it, but you would be upon it's limits so much, that you would NOT be able to operate it in the field with any efficiency.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 7:23am
The heaviest mounted plow A-C made was the 80 series 4 bottom, which weighed 1400 lbs.  Your 2500 lb drill might be closer to the rear wheels, which would help, but I still think it would take an S4 factory 3 point and a lot of front end weights to get that much lift accomplished.
This page was generated in 0.258 seconds.
