Wiring Harness Installation - wd-45
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Wiring Harness Installation - wd-45
    Posted: 07 Oct 2012 at 9:03am
Does anyone have a reference or could provide a few pictures showing the routing of the harness on the tractor.  I am tracking down the harness clips and need to figure out the routing of the wiring.
thanks!
Curtis
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 7:44am
I don't have any pictures, but I'll try to explain. For this post Left means left of the tractor when sitting on the seat.
THe whole harnass comes out of the instrument panal, preferebly with a rubber grommet around the slot the harness comes out of. From there it runs around the left side of the barrery box and on the left edge of the trans clutch cover. I have a wire clip held by one of the cover bolts, but I'm not sure if this is original. I have another clip on the left side of the clutch housing instection cover bolted to a cover bolt. After that the ignition wire runs under the starter over to the right side. I had to remove the start to get the wire under the starter. About where the clutch hoursing bolts to the frame rail the generator wires run into the inside of the frame rail and to the generator.
Hope this helps. If you still need pictures I can get some but it may be a couple days.
