Which Joystick
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: Which Joystick
    Posted: 10 Apr 2017 at 12:00pm
Got the plumbing all figured out thanks to forum members, So I'm finally getting ready to order a joystick for the front end loader. Looking at Prince valves with power beyond.   Would an 11 GPM work on a 185? I think the factory spool uses 10 GPM. Should I just get a 25 GPM for plenty of volume?
Tim
2-B's,CA,D15,D17,160,2-185's 8010
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 12:07pm
Open-Center with Power-Beyond. Figuring you wouldn't be using the loader at wide open throttle, I guess 11 GPM would work. But if the 25 GPM isn't very much more money???? it would be more than you need but....
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 3:20pm
I would go with the higher flow. It will work with a 11 gpm but it will cause the oil to heat up. I saw this on my 190XT with a 16 gpm valve.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 7:40am
Thanks. It's only a $40 dollar difference.
