Were some Band C front hubs different? |
Dean(IA)
Topic: Were some Band C front hubs different?Posted: 20 Sep 2011 at 8:52am |
The 41 C front tires are about 1" apart at the bottom and the CA sitting
next to it has about 2" of space at the bottom. Were some B and C hubs different? The hubs assembled normally onto the spindles, but the 5:00 X 15 new tires rub on the top of the pedestal on the C. |
Jeff Z. NY
Posted: 20 Sep 2011 at 9:05am |
There were several hubs used over the years.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Posted: 20 Sep 2011 at 10:10am |
I think your tires are too big. 'C' specs show 4.00 X 15 as the tire size. CA used 5.00 X 15.
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 20 Sep 2011 at 12:02pm |
OK But a C and a CA NF have the same Spindal Assembly part # 225121. The CA hubs look the same as a C hub but have different part numbers as do the rims themselves. Pretty sure they will interchange though. All the B C CA hubs use the same bearings and seals. There may be a slight difference in the hub or wheel the offsets but I don't think so.
Alberta Phill is right on about the tire spec size difference
