Wd45 running rough
Psdiesel350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 running rough
    Posted: 01 Aug 2020 at 8:07pm
things we have replaced /rebuilt:
Rebuilt carb, New points, condensor,cap, rotor, plug wires, plugs, set the valves, and sprayed ether around manifolds. Only thing I haven't done was to check compression or actually time it with a timing light. I did hook up a timing light to the plug wires and it was randomly cutting out. I dont know where to go from there.
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 8:44pm
Set your timing with a timing light FIRST.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 8:45pm
Check for slop in the distributor shaft.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 8:54pm
I took distributer off tonight and tore it apart it seems nice with not much slop. I haven't checked shaft from governor yet.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 9:31pm
Is this a 12V or 6V system? When you try to choke does it run better or worse?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 6:38am
I don't see replace coil. I'd try that
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 8:34am
Where did you get the new condenser? About 90% of them are junk right out of the box.
 I won't waste my time putting an off the shelf condenser in anymore. Go to NAPA and ask for Blue Streak ignition parts, or switch to a Pertronix electronic ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 3:09pm
Yep replaced coil. Actually put a 2nd set of points and condensor on with no change. If ya choke it get worse. If ya pull plugs out they are not wet, just black and sooty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 3:17pm
These are hard because were not there but even on our own tractors trouble shooting problems may not be easy.
I have this gut feel that you may have a carb/ fuel problem/ Just a hunch. Do you have another good running carb to change?
The black plugs may be a indication of fuel issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psdiesel350 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 3:21pm
I have a wd. Would that carb run ok on a 45 just for a test?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 4:27pm
Does it have an inline resistor? Customer had an Farmall H that was running rough and came down to that resistor being bad.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 8:34pm
wd carb will run on 45--I have 2 runnin that way
