Wd45 running rough |
Psdiesel350
Topic: Wd45 running roughPosted: 01 Aug 2020 at 8:07pm |
things we have replaced /rebuilt:
Rebuilt carb, New points, condensor,cap, rotor, plug wires, plugs, set the valves, and sprayed ether around manifolds. Only thing I haven't done was to check compression or actually time it with a timing light. I did hook up a timing light to the plug wires and it was randomly cutting out. I dont know where to go from there. Thanks |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7638 |
Posted: 01 Aug 2020 at 8:44pm |
Set your timing with a timing light FIRST.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 01 Aug 2020 at 8:45pm |
Check for slop in the distributor shaft.
1957 WD45 dad's first AC
Psdiesel350
Posted: 01 Aug 2020 at 8:54pm |
I took distributer off tonight and tore it apart it seems nice with not much slop. I haven't checked shaft from governor yet.
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 01 Aug 2020 at 9:31pm |
Is this a 12V or 6V system? When you try to choke does it run better or worse?
dr p
Joined: 24 Feb 2019 Location: new york Points: 1535 |
Posted: 02 Aug 2020 at 6:38am |
I don't see replace coil. I'd try that
CTuckerNWIL
Posted: 02 Aug 2020 at 8:34am |
Where did you get the new condenser? About 90% of them are junk right out of the box.
I won't waste my time putting an off the shelf condenser in anymore. Go to NAPA and ask for Blue Streak ignition parts, or switch to a Pertronix electronic ignition. |
Psdiesel350
Posted: 02 Aug 2020 at 3:09pm |
Yep replaced coil. Actually put a 2nd set of points and condensor on with no change. If ya choke it get worse. If ya pull plugs out they are not wet, just black and sooty.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 02 Aug 2020 at 3:17pm |
These are hard because were not there but even on our own tractors trouble shooting problems may not be easy.
I have this gut feel that you may have a carb/ fuel problem/ Just a hunch. Do you have another good running carb to change? The black plugs may be a indication of fuel issues? Regards, Chris
Psdiesel350
Posted: 02 Aug 2020 at 3:21pm |
I have a wd. Would that carb run ok on a 45 just for a test?
Boss Man
Posted: 02 Aug 2020 at 4:27pm |
Does it have an inline resistor? Customer had an Farmall H that was running rough and came down to that resistor being bad.
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 02 Aug 2020 at 8:34pm |
wd carb will run on 45--I have 2 runnin that way
