WD45 question
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Topic: WD45 question
    Posted: 03 May 2015 at 4:32pm
I have a 45 with an E Gleaner engine. Was wondering if I could plug the water bypass hose off on water pump. The tractor only runs maybe 10 min. at a time when we're pulling.Thanks.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2015 at 7:02pm
  i know of engines out there with  very little water capaciyy-- blocks are full of filler
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2015 at 8:45pm
If I was going to do that, I would ram a screwdriver down thru the thermostat so it couldn't close. That will keep the water moving thru the block and head, which is what the bypass hose did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2015 at 2:30pm
Ok thanks I can just remove the thermostat. Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2015 at 3:40pm
I didn't say remove the stat. I said disable it so it's open all the time so water constantly flows thru it with SOME restriction. Suit yourself.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2015 at 6:10pm
There's a myriad of conceptions on how presence or lack of restriction in the cooling system impacts a given engine, and I suspect the results are highly subjective to the application and it's operating conditions, but I will say with certainty, that drastically changing the flow character of coolant through an engine, frequently results in a substantial impact to the way it moves waste heat from one area to another, and frequently, that impact is not beneficial.
I know with certainty, that removing outlet restriction on say.... marine cooling systems, that the raw water pump, and cooling pump rapidly lose the ability to remove waste heat from cylinder heads, because the lack of discharge restriction prevents the pump from pressurizing cooling water enough to prevent boiling in upper hot spots.
I won't say it DOES happen with an Allis, but I'd suggest that since these cooling systems operate at essentially atmospheric pressure, that yanking the thermostat completely is likely to have unwanted result.
But another question perplexes me... what is the advantage of removing the bypass hose? It weighs essentially nothing, and there's no improvement to be had by yanking it...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2015 at 8:12pm
I am putting a charlynn pump on and it is in the way
