WD45 question
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=105620
Printed Date: 10 Sep 2025 at 5:59am Software Version: Web Wiz Forums 11.10 - http://www.webwizforums.com
Topic: WD45 question
Posted By: Jim NEIN
Subject: WD45 question
Date Posted: 03 May 2015 at 4:32pm
I have a 45 with an E Gleaner engine. Was wondering if I could plug the water bypass hose off on water pump. The tractor only runs maybe 10 min. at a time when we're pulling.Thanks.
Posted By: norm[ind]
Date Posted: 03 May 2015 at 7:02pm
i know of engines out there with very little water capaciyy-- blocks are full of filler
Posted By: DrAllis
Date Posted: 03 May 2015 at 8:45pm
If I was going to do that, I would ram a screwdriver down thru the thermostat so it couldn't close. That will keep the water moving thru the block and head, which is what the bypass hose did.
Posted By: Jim NEIN
Date Posted: 04 May 2015 at 2:30pm
Ok thanks I can just remove the thermostat. Thanks again.
Posted By: DrAllis
Date Posted: 04 May 2015 at 3:40pm
I didn't say remove the stat. I said disable it so it's open all the time so water constantly flows thru it with SOME restriction. Suit yourself.
Posted By: DaveKamp
Date Posted: 04 May 2015 at 6:10pm
There's a myriad of conceptions on how presence or lack of restriction in the cooling system impacts a given engine, and I suspect the results are highly subjective to the application and it's operating conditions, but I will say with certainty, that drastically changing the flow character of coolant through an engine, frequently results in a substantial impact to the way it moves waste heat from one area to another, and frequently, that impact is not beneficial.
I know with certainty, that removing outlet restriction on say.... marine cooling systems, that the raw water pump, and cooling pump rapidly lose the ability to remove waste heat from cylinder heads, because the lack of discharge restriction prevents the pump from pressurizing cooling water enough to prevent boiling in upper hot spots.
I won't say it DOES happen with an Allis, but I'd suggest that since these cooling systems operate at essentially atmospheric pressure, that yanking the thermostat completely is likely to have unwanted result.
But another question perplexes me... what is the advantage of removing the bypass hose? It weighs essentially nothing, and there's no improvement to be had by yanking it...
------------- Ten Amendments, Ten Commandments, and one Golden Rule solve most every problem. Citrus hand-cleaner with Pumice does the rest.
Posted By: Jim NEIN
Date Posted: 04 May 2015 at 8:12pm
I am putting a charlynn pump on and it is in the way
