Wd45 main bearings
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 main bearings
    Posted: 28 Sep 2012 at 10:59am
Guys how will I know if I need to get new mains I'm taking out the pistons now what to look for?
1946 "C"
1956 "WD45"
1965 "D17" Series IV
1979 185 factory ROPS
deutz allis 385 planter
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 11:22am
Scores, wear lines in crank or bearing, copper showing through, rough surface of crank, uneven wear,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 11:44am
Guys the crank doesn't seem bad but the main bearings are scored
1946 "C"
1956 "WD45"
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 1:10pm
A few scratches in the bearing face mean there has been dirt in the oil. They can be cleaned up and reused if money is a problem. If you have wear or "scored" where you see areas of bronze thru the surface, that is excessive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 1:13pm
Looks like I'm gonba get it ground anyways how do I clean all the crap out of my engine so this don't happen agaib
1946 "C"
1956 "WD45"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 1:31pm
Mic the crank to see how much wear there is and if round , between rod and main wear in might not need regrinding, a few scores are normal IF the bearings have run for years.
 As far as cleaning must should clean out well with just normal shop cleanleyness and flushing oil through passages with a good pump oil can .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2012 at 1:35pm
Okay thank you ill check it
1946 "C"
1956 "WD45"
