WD45 Hydraulic leak
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulic leak
    Posted: 09 Nov 2020 at 3:24pm
I have attached a photo of my WD45 Hydraulic leak.  It appears to drip from the valve at the rear (where the arrows are pointing.  down onto the pump itself.  Is there a seal kit parts number for this?
Edited by twinsonfarm - 09 Nov 2020 at 3:46pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 8:58pm
There is a oring and packing on both  sides. Screw in front of valve has to come out to remove shaft.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 8:59pm
Thank you.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 6:50am
The detent ball will fall out and bounce a couple times then disappear, so get ready.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 8:07am
Lon's comment is a good reason to work on these assemblies inside a box so the little bits have a harder (note that I didn't say "impossible") time escaping!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 8:17am
Thank you guys.  Parts ordered from Agco.
Aaron123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 2:41pm
I rebuilt my hydraulic valve on my 1954 WD45 and I got all the stuff at sandy lake implements here is there web site sandylakeimp.com
I had my wd45 parts cataloge and they had the same thing and we talked through What I meeded.. they where the only ones I found that knew what I needed
This page was generated in 1.465 seconds.
