WD-45 hydraulic cylenders
lmc122 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lmc122 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 hydraulic cylenders
    Posted: 12 Dec 2011 at 1:49pm
The hydraulic cylenders on my WD-45 leak, is there a way to tighten the packings with out pulling the cylinders apart. Never took a hydraulic cylender apart before so pictures would be great. The cylenders don't leak bad just drip. Thanks
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 1:59pm
The cylinders on the lift arms have a "packing "nut that can be turned up to stop a small dripping. It often doesn't take much and should not be turned tight or the cylinder will bind.
regards,
Ken McGregor
Post Options Post Options   Thanks (0) Thanks(0)   Quote lmc122 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 2:28pm
Where is the packing nut? can you get to it on the out Side or do you have to pull the cylender apart? Thanks
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 3:07pm
Look at the rod end of the cylinder. it has a thin hex part on it the is the packing nut. Allis cylinders are a displacment cylinder. No seals of any kind inside the cylinder. don't tighten to tight it will bind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lmc122 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 3:46pm
Thanks, that's where I thought it was, just wanted to be sure.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 8:52pm
There are vee packing seals in the lift cylinders . I think they are 2 inch od by 1 1/2 id and sold by a 1 inch stack.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 8:58pm
You say ypu never had a hydraulic cylender apart.
I never even heard of one.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 9:00pm
Did I say ypu???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 9:01pm
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 9:34pm
      You DA MAN Jeff !!!
