Print Page | Close Window
WD-45 hydraulic cylenders
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=42022
Printed Date: 29 Aug 2025 at 5:47pm
Topic: WD-45 hydraulic cylenders
Posted By: lmc122
Subject: WD-45 hydraulic cylenders
Date Posted: 12 Dec 2011 at 1:49pm
The hydraulic cylenders on my WD-45 leak, is there a way to tighten the packings with out pulling the cylinders apart. Never took a hydraulic cylender apart before so pictures would be great. The cylenders don't leak bad just drip. Thanks
Posted By: Ken McGregor
Date Posted: 12 Dec 2011 at 1:59pm
The cylinders on the lift arms have a "packing "nut that can be turned up to stop a small dripping. It often doesn't take much and should not be turned tight or the cylinder will bind.
regards,
Ken McGregor
Posted By: lmc122
Date Posted: 12 Dec 2011 at 2:28pm
Where is the packing nut? can you get to it on the out Side or do you have to pull the cylender apart? Thanks
Posted By: Dakota Dave
Date Posted: 12 Dec 2011 at 3:07pm
Look at the rod end of the cylinder. it has a thin hex part on it the is the packing nut. Allis cylinders are a displacment cylinder. No seals of any kind inside the cylinder. don't tighten to tight it will bind.
Posted By: lmc122
Date Posted: 12 Dec 2011 at 3:46pm
Thanks, that's where I thought it was, just wanted to be sure.
Posted By: REEDE
Date Posted: 12 Dec 2011 at 8:52pm
There are vee packing seals in the lift cylinders . I think they are 2 inch od by 1 1/2 id and sold by a 1 inch stack.
Posted By: Jeff Z. NY
Date Posted: 12 Dec 2011 at 8:58pm
You say ypu never had a hydraulic cylender apart.
I never even heard of one.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Date Posted: 12 Dec 2011 at 9:00pm
Did I say ypu???
Date Posted: 12 Dec 2011 at 9:01pm
Posted By: Auntwayne
Date Posted: 12 Dec 2011 at 9:34pm
      You DA MAN Jeff !!!
