wd45 hand clutch
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: wd45 hand clutch
    Posted: 02 Jun 2017 at 11:44pm
Getting ready to adjust the hand clutch on my 45.  Anyone got the procedure for it.  I know it has to do with shims, but do you add, remove, or reposition the existing shims.  Thanks
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 12:53am
you haft to remove a few shims at a time an try it tell you get a good tite snap back in your clutch' should pull back an lock in push ahead with a good snap' remember make sure to take the same amount of shims out of each place.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 7:46am
save the old shims you may need them later.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 9:43am
Always check your clearance before you start. Put a feeler gauge down between the clutch pack with the clutch disengaged, find out what the clearance currently is. It needs to be between .035" and .065" I shoot for .045" remove enough shims equally  from the three stacks to  get your clearance. if you go to tight the clutch wont disengage correctly. While you have the cover off look aft and check the condition of the brass collar on the throw-out bearing fork. If the tractor is one that sat running constantly with the hand clutch disengaged that brass collar will be worn out and no amount of shimming will fix it.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2017 at 12:29pm
I hope this thread makes it to the knowledge base section!
This page was generated in 0.254 seconds.
