WD45 Front Axle Fun & Frolic - Update |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Topic: WD45 Front Axle Fun & Frolic - UpdatePosted: 19 Apr 2017 at 8:33pm |
Two days ago I adjusted the rear wheels on my WD45. Took 5 minutes, partly as this was the first time I'd ever done this.
This morning I started working on moving the front wheels in to line up with the rears. As easy as adjusting the rears was, this promises to be the job from h*&%. I started on the right side. It took the hot wrench and my impact wrench to remove the two bolts that secure the stub axle to the center axle. The bolt in the clamp on the tie rod came out without any fuss. So far, so good, I thought. I've got this! Which immediately demonstrated that pride does indeed go before a fall....neither the stub axle nor the tie rod stub would move a millimeter. I decided to remove the tie rod since the tie rod end and the rod itself seem welded together by rust. Time for a quick trip to NAPA for a pickle bar as neither end of the rod wanted to come loose. No sweat - I needed one in my tool chest anyway! Before I return to the battle tomorrow armed with my pickle bar, are there any tips on getting the two parts of the tie rod apart? Thanks for your help! Dave
Edited by Dave(inMA) - 25 Apr 2017 at 6:08pm |
WC, CA, D14, WD45
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4072 |
Posted: 19 Apr 2017 at 10:49pm |
heat and rap on the side of it with a hammer on the anvil start working the rust out the ends
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 19 Apr 2017 at 11:32pm |
You don't need a pickle bar on these small tie rod ends. Just hit the eye on the end of the tie rod on the side with a heavy hammer and it will pop loose in a few licks. Loosen the tie rod nut first and run it to the end of the tie rod to protect the threads.
Dave(inMA)
Posted: 20 Apr 2017 at 6:02am |
Thanks for the advice, guys. Much appreciated.
Another question - I'm wondering how much of the tie rod "stub" is buried inside the tie rod tube? The exposed length is about 5.75".
WC, CA, D14, WD45
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 20 Apr 2017 at 7:43am |
The tie rods are made to extend as far as the axle. |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 20 Apr 2017 at 8:00am |
The tie rods will come apart with the fire wrench. I heat a part until red hot then move to another part until I've heated all of the area where they are slid together.
Wink I am a Russian Bot |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3131 |
Posted: 20 Apr 2017 at 8:37am |
If the end are very loose and wore you can buy new ones about $70 each or $140 total for everything.
Dave(inMA)
Posted: 20 Apr 2017 at 10:33am |
Thanks for all that, guys. Hoping I can get time today to get them apart.
WC, CA, D14, WD45
Dakota Dave
Posted: 20 Apr 2017 at 10:59am |
I gave up on my tierods and replaced them. The new ones move real easy. I don't think the originals had been moved since new the boots were shot and they had play in them. I did the beat and heat on the axle sections and used a high lift jack to spread them . I decided to not move them on the other WD 45 there staying where they are.
Edited by Dakota Dave - 20 Apr 2017 at 11:01am |
Dave(inMA)
Posted: 20 Apr 2017 at 11:07am |
Oh boy! Hope I have better luck than you, Dave.
WC, CA, D14, WD45
Dakota Dave
Posted: 20 Apr 2017 at 3:23pm |
I figured if they broke when I was trying to free them up they needed to be replaced anyway. Even though none of my tractors ever go on the road. steering and brakes are the two most things on the tractor.
Dave(inMA)
OK. Tie rods are off the tractor and have been heated a LOT. Waiting for them to cool so I can try to move the inner rod.
One boot is shot. There's a little slop in the ends that attach to the steering "plate" under the engine. Stay tuned!
Edited by Dave(inMA) - 20 Apr 2017 at 4:23pm |
WC, CA, D14, WD45
Allis dave
Posted: 20 Apr 2017 at 3:34pm |
You may already know this, but you can spray some good penetrating oil on the crack and in the holes while it's hot. Somehow the heat helps to wick the oil up inside. Run out and spray on some oil! lol
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3195 |
Posted: 20 Apr 2017 at 3:35pm |
Drop them in a bucket of oil and go buy new ones,by the time the new ones wear out those MIGHT be loose.
Tony.Or
Posted: 20 Apr 2017 at 4:57pm |
Dave ! Your tie rods are ordered.. Thanks Tony
Dave(inMA)
Posted: 20 Apr 2017 at 4:59pm |
I have tried all the tricks I know and all of your suggestions. Those *&%$# rods won't budge. Two of the ends are sloppy......life is too short. I have ordered replacements. The axles are all set - all bolted up with new #8 bolts and a dose of anti-seize on each.
Thanks for the encouragement, guys! And thanks to Tony for the parts.
Edited by Dave(inMA) - 20 Apr 2017 at 5:01pm |
WC, CA, D14, WD45
DanC911
Posted: 21 Apr 2017 at 9:01pm |
I've used wax on stuck bolts and nuts. Heat it red hot and touch a old candle to the threads. It gets in there and loosens things up. Don't see why the same trick wouldn't work here. |
Dave(inMA)
Posted: 21 Apr 2017 at 10:22pm |
Thanks, Dan. I haven't tossed the old tie rods yet....will try this technique. It'd be nice to find something that does the job!
WC, CA, D14, WD45
Gary Burnett
Posted: 22 Apr 2017 at 8:02am |
If you're interested in messing with the old ones I've had good results of tying one end to something solid and hooking a com-a-long to the other end and keep them under constant pressure sooner or later they usually move.
Dave(inMA)
Posted: 22 Apr 2017 at 8:05am |
Interesting, Gary - I've been thinking about ways to put constant pressure - either push or pull - on them. I was thinking that constant 'push' might bend something, but I like constant 'pull'. May just try this!
WC, CA, D14, WD45
Gary Burnett
Posted: 22 Apr 2017 at 8:13am |
Just try to get a notch on the com-a-long when you go by sometimes.
Dave(inMA)
Posted: 22 Apr 2017 at 11:19am |
Got one of them strung up between two stout trees. Used a load binder...easier to get a notch than with the come-a-long. I think one of the trees is starting to lean.
![]() Edited by Dave(inMA) - 22 Apr 2017 at 11:20am |
WC, CA, D14, WD45
Dave(inMA)
Posted: 25 Apr 2017 at 6:07pm |
New tie rods arrived today and are installed! They seem very solid and should certainly do the job. I coated the inner rods with Never Seize - hope that helps. Of course, it's now pouring rain here, so getting into the field with the plow will have to wait a day or so.
I've had one of the old tie rods strung between two trees - it's been under tension for 3 days now but hasn't budged. Put the other one in my 20 ton press and 'leaned' on it until the rod began to bow. With the new ones installed, I guess I'm stubborn enough to want to get the old ones apart! Thanks for all the help with this!
WC, CA, D14, WD45
