WD45 Final Drive Question
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Final Drive Question
    Posted: 02 Oct 2011 at 6:49pm
I just replaced the bearings and bearing races in right side drive housing. Everything went in OK, got the seal seated, and the inner bearing on. Now, how much do you tighten the inner axel retaining bolt? The end play was out of it way before the bolt was even kind of tight. I snugged it down every thing still rotated fine. Just wondering how tight should I make it? I ordered a couple of 0.002" shims with the bearing kit. Should I use those?
Jeff
1954 WD45 NF "Iron Tater"
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 8:44pm
jeff..according to my wd-45 ohm,you tighten down to a free rolling,no binding fit.i had one apart awhile back and it worked for me.just be certain you have no axial movement on the hub.sounds like you are doing fine....
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 8:58pm
Tighten the bolt down tight with the shims under the washer. If there is inplay remove shims until all end play is gone. MACK
