Wd picker project |
Page 12> |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1352 |
Topic: Wd picker projectPosted: 14 Sep 2021 at 10:54am |
Hey a’ll,
Well I started another project: a WD with a 33 picker. It has real good spark but won’t fire even with starting fluid so I’m completely lost of what to do.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34642 |
Posted: 14 Sep 2021 at 11:10am |
Is it timed right?
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 1003 |
Posted: 14 Sep 2021 at 11:46am |
Put some oil in the cylinders.
Life is simpler when you plow around the stump.
55allis
Posted: 14 Sep 2021 at 1:27pm |
JC, it ran when it was parked.
Joe, I put some PB-Blaster in the plug holes. I put new old stock points on and cleaned and set them at .020”. Not sure if that right? |
farmboy520
Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Posted: 14 Sep 2021 at 2:20pm |
Made sure there isn't a mouse nest in the intake?
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
55allis
Posted: 14 Sep 2021 at 2:43pm |
That’s very possible, the air cleaner wasn’t and isn’t on it....
55allis
Posted: 19 Sep 2021 at 10:10am |
I found the problems, I was one spark plug wire off and the carb is gummed up so I put a old Zenith carb that I took off my 49 Wd( I put a marvel schebler the 49 Wd) and it ran like a good Allis should!!
JimIA
Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1991 |
Posted: 19 Sep 2021 at 10:24pm |
Did you install new spark plugs? Seen that before with old plugs, spark very well when not in the cylinder but wouldnt work when in the cylinder.
55allis
Posted: 19 Sep 2021 at 10:48pm |
I switch them with a set I had sitting around for quite a while, I pretty sure they are new but they’re Champions so I will put Autolights in it after a while.
And like I said it runs like a good Allis should. |
55allis
Posted: 20 Sep 2021 at 9:27pm |
I ordered a set of 13.6-28 tubes and took a rim in to my local welding shop to fix around the valve stem ( it had rust holes).
The tractor is still 6v so thinking of the pluses and minuses of putting it to 12v. Napa can get the 6v battery for $101.99 bucks!! ![]()
55allis
Posted: 24 Sep 2021 at 10:19am |
Well I got the rim back and painted both and got the one on, now it’s just trying to get the other side off and put the tire on. Both back tires had fluid in them...
55allis
Posted: 24 Sep 2021 at 11:26pm |
I found out to day that the water pump leaks but it’s not lose, it just drips a lot.
I started the picker and everything was working and decently quiet, the blower fans aren’t hooked up yet so not sure how they hook up if anyone has any ideas or pictures? I think I got a hunch that the 6 holes on the back part of the frame rails have something to do with it? |
dr p
Joined: 24 Feb 2019 Location: new york Points: 1546 |
Posted: 25 Sep 2021 at 5:57am |
Grab a manual off Ebay. Helped me find the 12 million grease fittings on the picker
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5489 |
Posted: 25 Sep 2021 at 4:25pm |
I was going to switch my WD to 12v until I changed out the battery cables to 1/0 wielding cables. What a huge difference!!! It spins the motor like a 12v. Left mine stock 6v. That was 3 years ago, still strong spinning it over. I prefer to leave it stock as it came from AC.
55allis
Posted: 25 Sep 2021 at 10:04pm |
How long have you had the 6v battery? I’ve heard that those battery don’t last long? |
AC720Man
Posted: 26 Sep 2021 at 6:00pm |
3 years
AC720Man
Posted: 26 Sep 2021 at 6:01pm |
I put a 6v battery tender on it in the winter
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 26 Sep 2021 at 10:53pm |
55,
Nice picker project! Have fun with the old girl. Items you found sound about right. I like them switched to 12 volt. But thats just me they will run and start very well on 6 Volt too.
Regards, Chris |
Don(MI)
Joined: 15 Sep 2009 Location: Michigan Points: 3941 |
Posted: 27 Sep 2021 at 3:50pm |
What a beauty and best of luck!
I can't remember how the blowers bolt on, but I leave the belt off mine inless it's picking. If you do a corn picker search on here and find some posts with my name, i probably have a picture of it for ya |
Galatians 5:22-24
"I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!" |
55allis
Posted: 29 Sep 2021 at 10:51pm |
Well today I brought it home to try it out on some popcorn we planted as soon as it dries up a bit( it was a five mile trip and I drove it).
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11426 |
Posted: 30 Sep 2021 at 1:23pm |
Looks good, do you have the side covers for the engine, I wouldn't pick any corn without them
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4285 |
Posted: 30 Sep 2021 at 2:02pm |
Nice!
55allis
Posted: 30 Sep 2021 at 2:54pm |
Yes I do, I have them off to work on the tractor. Also have the front screen that covers the radiator shell. I will get a picture of it with everything on. |
AC720Man
Posted: 30 Sep 2021 at 3:21pm |
I would guess once a picker got added to a WD it rarely come off due to the complexity of mounting it? Would be neat to watch it pick corn. Has to be a very noisy and dirty job running one.
55allis
Posted: 30 Sep 2021 at 8:27pm |
The noise part I got a cured, I have head phones!!
Today I changed the engine oil and the air cleaner oil, found out it had a mouse nest in it... and no it didn’t make it in to the carb, I caught it before it did. |
55allis
Posted: 01 Oct 2021 at 11:24am |
Here’s a picture of it with the shields.
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Posted: 01 Oct 2021 at 1:05pm |
that's a great picture
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1156 |
Posted: 01 Oct 2021 at 1:53pm |
I agree nice picture. Gavin what are you using for a wagon.
plummerscarin
Posted: 01 Oct 2021 at 3:19pm |
Yay, great picture
55allis
Posted: 01 Oct 2021 at 6:46pm |
I got a wagon I think might work.
Page 12> |
