WD motor |
jacnmars ![]() Bronze Level ![]() ![]() Joined: 31 Aug 2012 Location: Indiana Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: 31 Aug 2012 at 6:07pm |
What other tractors will the motor from my WD bolt into?
Bob D. (La) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
B, C, CA, WD, and WD45. Pretty sure it will go in a d17 as well.
Guests ![]() Guest Group ![]() |
It will bolt into a WC, WD, WD45. Also WF and D17 assuming on the 17 that the bellhousing adapter is there. Otherwise, unless there is something I am horribly unaware of, It will NOT bolt into a b c or CA. I suppose you also need to mention the RC too, it will bolt into it.(although that would turn it back into a WC essentially)
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If a CE engine bolts to an RC and a WD engine will bolt to it, why can't a WD engine bolt to a CA? Never been around an RC so there must be something different.
Same deal I believe, there is a bell housing adapter for the RC to accomodate the C engine but as far as I know there is no way to go the opposite, that is a WD engine to a B C family rear end
Edited by oldorangeiron - 31 Aug 2012 at 7:25pm |
I want one then, the adapter I mean. Then turn it around backwards and bolt a WD engine in a CA
Wish I had an RC and I'd see if it was even possible
![]() Might be neat!
If you build it................ I have seen a GM V8 diesel bolted in place of a 2 cylinder JD engine. Anything's possible.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
When the 125 engine was used in the RC they didn't use the two top holes in the bell-housing. It is not possible to put the WC - WD engine into a B or C unless you have a large machine shop, there was one at the orange spectacular a few years ago that was major progect like one off flywheel and cutom sheet metal.
I figured there was a hitch to it, or else we would see it from time to time. Neat thought though I guess
thanks for the info will this engine bolt into all d series
No It will only work in the d17
