Print Page | Close Window
WD motor
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=56151
Printed Date: 08 Sep 2025 at 7:35pm
Topic: WD motor
Posted By: jacnmars
Subject: WD motor
Date Posted: 31 Aug 2012 at 6:07pm
What other tractors will the motor from my WD bolt into?
Posted By: Bob D. (La)
Date Posted: 31 Aug 2012 at 6:36pm
B, C, CA, WD, and WD45. Pretty sure it will go in a d17 as well.
Posted By: Guests
Date Posted: 31 Aug 2012 at 7:04pm
It will bolt into a WC, WD, WD45. Also WF and D17 assuming on the 17 that the bellhousing adapter is there. Otherwise, unless there is something I am horribly unaware of, It will NOT bolt into a b c or CA. I suppose you also need to mention the RC too, it will bolt into it.(although that would turn it back into a WC essentially)
Posted By: CTuckerNWIL
Date Posted: 31 Aug 2012 at 7:16pm
If a CE engine bolts to an RC and a WD engine will bolt to it, why can't a WD engine bolt to a CA? Never been around an RC so there must be something different.
Posted By: Guests
Date Posted: 31 Aug 2012 at 7:23pm
Same deal I believe, there is a bell housing adapter for the RC to accomodate the C engine  but as far as I know there is no way to go the opposite, that is a WD engine to a B C family rear end
Date Posted: 31 Aug 2012 at 7:28pm
I want one then, the adapter I mean. Then turn it around backwards and bolt a WD engine in a CASmile
Posted By: Guests
Date Posted: 31 Aug 2012 at 7:36pm
Wish I had an RC and I'd see if it was even possible LOL
Might be neat!
Date Posted: 31 Aug 2012 at 7:46pm
If you build it................ I have seen a GM V8 diesel bolted in place of a 2 cylinder JD engine. Anything's possible.
Posted By: B26240
Date Posted: 31 Aug 2012 at 7:49pm
When the 125 engine was used in the RC they didn't use the two top holes in the bell-housing. It is not possible to put the WC - WD engine into a B or C unless you have a large machine shop, there was one at the orange spectacular a few years ago that was major progect like one off flywheel and cutom sheet metal.
Posted By: Guests
Date Posted: 31 Aug 2012 at 8:00pm
I figured there was a hitch to it, or else we would see it from time to time. Neat thought though I guess
Posted By: jacnmars
Date Posted: 01 Sep 2012 at 6:27am
Posted By: jacnmars
Date Posted: 01 Sep 2012 at 6:31am
thanks for the info  will this engine bolt into all d series
Posted By: Guests
Date Posted: 01 Sep 2012 at 7:05am
No It will only work in the d17
