WD middle steering shaft support.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: WD middle steering shaft support.
    Posted: 19 Aug 2012 at 7:51pm
The middle steering shaft support that bolts to the frame rail underneath the gas tank is worn out on my WD bad. (as most of them are) is anyone making aftermarkets or is there away to fix it? Thanks Josh
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2012 at 8:33pm
The support can be bored and rebushed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2012 at 8:41pm
The one on my WC was wore real bad on the bottom side so I centered a shaft in it with silicone release agent on it and filled it with epoxy. The shaft was a little rough too and I drove the tractor on the trailer before adding any grease so it opened it up a little for meUnhappy but it still is way better than it was.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2012 at 10:14pm
I bored mine out enough to accept a quadrant bushing
