WC Clutch |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Topic: WC ClutchPosted: 11 Jul 2017 at 4:58pm |
My '38 WC has been to a bunch of local tractor pulls and has done pretty well. It was still in with the big boys at Sunday's pull, though that didn't last too long!
BUT she may be getting a bit tired! The clutch doesn't engage until just as the pedal reaches the end of its travel. I'm also getting a small bit of chatter as the clutch engages. So two questions:
1. Can I adjust the clutch linkage so the clutch engages earlier? 2. Do these symptoms suggest that it might be time for a new clutch? Thanks much! Dave |
WC, CA, D14, WD45
Dave(inMA)
Posted: 12 Jul 2017 at 3:20pm |
bump!
WC, CA, D14, WD45
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 12 Jul 2017 at 4:04pm |
Without a manual in front of me.....I would adjust the pressure plate levers, failing that you need replacement. There is no other adjustment I know of.
Dave(inMA)
Posted: 12 Jul 2017 at 4:56pm |
Thanks, Gary. Kinda my impression, but I've never had one of these to deal with!
WC, CA, D14, WD45
Posted: 13 Jul 2017 at 7:17am |
Let's say when that old clutch was brand new, you had 4 inches of free-travel at the clutch pedal. Thru normal wear and tear, that 4 inches of free-travel will eventually go to zero. Adjusting the clutch pedal rod or the pressure plates finger height might create some new free-travel BUT, the disc may be worn too thin that you could have slipping problems anyway, which would mean time for a new clutch.
Dave(inMA)
Posted: 13 Jul 2017 at 11:52am |
Makes total sense, Dr! I have no idea how old that disc is, but I'd guess that tractor pulls over the last 10-15 years have worked it pretty hard. I'm hoping to get it in my shop over the winter and replace the clutch.
Thanks! Dave
WC, CA, D14, WD45
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12045 |
Posted: 13 Jul 2017 at 2:48pm |
Dave,
Talk to Rick about a clutch assy. He'll fix ya up. He does a nice job and very reasonable to! I get my clutches from him. No problems yet. Steve@B&B |
