WC allis steering wheel restoration
psheridan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Topic: WC allis steering wheel restoration
    Posted: 09 Nov 2016 at 8:56pm
I have found a period correct steering wheel for my 37 WC
does anyone have experience in restoring the bakelite material on the wheel
I have seen clips on using bondo,
Thanks
Paul
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 11:04pm
i coated one around 3 years ago with flex-seal. it's still holding up good' it works good for handles on tools also.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 11:36pm
I hear flex seal also works good on All-Crop draper drive rollers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2016 at 11:40pm
it takes time to set-up but it works good.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2016 at 12:31pm
If your steering wheel has gaps or even if there are pieces missing,
PC7 2-part epoxy works very well to fill in.  It has about the same consistency & density as bakelite.
What I've found is that a good day between layers is required for it to cure out.
If too soon, the stuff will gum up whatever tool you're using to shape or file it.
I changed a '40 Chrysler steering wheel from stock 18" diameter down to 16" dia
using a slightly dull, half-round wood rasp to shape the contours.
Took quite a while, but turned out good.
This page was generated in 0.071 seconds.
