wagon vs trailer |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Topic: wagon vs trailerPosted: 22 Jul 2021 at 5:37am |
Ok, I'm kinda bored and started to wunder..... Say a tractor is rated to pull 3000#, could you pull more using a 4 wheel 'wagon' instead of a 2 wheeled 'trailer' ? To me a 'trailer' (1 or 2 axle) puts some of the weight on the tongue ,so backend of the tractor .. but a 'wagon' doesn't have any 'tongue' weight . I've seen pics of tractors pulling 2-3 wagons of big bales,got be curious about load capacity of trailer vs wagon.... Jay
Posted: 22 Jul 2021 at 5:50am |
Any time you put downward force on the drawbar you are boosting the traction.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 22 Jul 2021 at 6:59am |
Pulling something like a wagon, yeah, you'll lose traction before you run out of power most likely. Depends on so many things. How fast are you going to pull it, what surface are you on, any slope, how much does your pulling vehicle weigh, and how quickly do you want to get it moving (acceleration) . Force = mass * acceleration. I've pulled 120 square bales on a wagon with a 335cc quad. Don't make a habit of it, but I did it. Get something with tongue weight, a lot of it, and you can draw your tractor right down to stall without spinning.
Edited by Tbone95 - 22 Jul 2021 at 7:00am |
Joined: 11 Sep 2009 Location: illinois Points: 90868 |
Posted: 22 Jul 2021 at 8:00am |
just make sure you got the BRAKES for the load !
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Posted: 22 Jul 2021 at 8:11am |
The big issue with applying too much tongue weight would be draw bar rating. We have sheared a draw bar before with a fertilizer cart (guessing it was shock loaded). I would just guess that ~1200#’s would be around max weight for a 180-200 draw bar, then the 3 pt would handle up to 4000-5000#’s for optimum traction, heavier would need to be distributed over multiple wheels like a wagon.
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 22 Jul 2021 at 8:41am |
If you should need to back up, a trailer is a lot easier.
Dusty
Luke114
Joined: 27 Aug 2019 Location: Washington Points: 109 |
Posted: 22 Jul 2021 at 10:36am |
Sounds like an interesting math problem expressed with some differential equations including variables of mass, friction, traction, gravity, slope, beers consumed, etc.
My gut reaction is 4 wheel wagon for fairly flat and dry ground, trailer for conditions where traction is an issue. And if you are pulling your hay wagon through the mud, traction may be the least of your worries!
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Posted: 22 Jul 2021 at 10:43am |
I agree with Steve, its more for Braking safety (IMO) Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Posted: 22 Jul 2021 at 3:28pm |
Most trailers have brakes, most wagons don't. Also, most wagons are not rated for higher speeds.
Posted: 22 Jul 2021 at 3:53pm |
Im thinking pulling a 10,000 pound wagon down a hill with a 4000 pound tractor... TRACTOR better have brakes.
