Wagon gear center pipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Wagon gear center pipe
    Posted: 26 Oct 2016 at 10:40pm
Hi everybody. Has anyone ever replaced the pipe that goes between the rear axle to front. The company that made the running gear isn't in business anymore. What would you use to replace it. Thanks
Edited by Mikez - 26 Oct 2016 at 10:58pm
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:11pm
i went to a steel yard an got a new pipe same size out side with like 1\2 in'' wall pipe' an drilled new holes in it an was like a new gear for around $20oo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:16pm
Oh good idea
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:23pm
you can cut it how ever long you care to have it. for a grain wagon you want it short an strong. do a good job'' Smile
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:35pm
yeah....don't buy thin wall pipe. and you want your box runners to sit a least a foot out on each end of the bolsters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 11:43pm
shameless' that 1\2 wall pipe is stout as he'''\\ thank it will be good i used it on one with a 185 grain box w\ side board that size should do it  RIGHT''
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 5:36am
I had one done by a machine shop.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 6:54am
All depends on the size of the running gear.
The one on my Cobey running gear with a Precision flare box is even 1/4". It has 4 bolt hubs. 1/2" pipe on a 2 ton running gear is overkill. Now on a 10 ton, maybe. Best thing to do would be to find a comparable size one and see what size it uses. Any more than a couple inches sticking out each end is a waste, because it has nothing to leverage against.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 8:59am
I think if you check the old tube it's not pipe it's round mechanical tubing, check the OD and ID of the tubing and if it has a tube inside a tube you need to get seamless tubing too before just going to the big box store and finding a piece of water pipe that will go in the hole. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 9:50am
I personally have never seen one thicker than a 1/4 inch. Most are closer to 3/16. I have made several. Depends on the gear maker. Most of the Electric Wheel gears use same size gage pole. HTH Tracy
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 11:36am
That "center pipe" is called a "reach" going way back to the old horse drawn wagons when it was made of wood.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 11:58am
WE called that center piece on horse drawn wagons a coupling pole .{coupled front to rear } Had holes in it to extend wheelbase .
Rick143 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick143 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 12:30pm
We always called it a reach also. My dad use to build a lot of running gears and he used pipe also. If it was a heavier gear he would schedule 80 pipe also known as double strength pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 12:42pm
Yea sometimes we call it a reach too. Thanks for the good advise
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 2:20pm
I believe in some cases you will find it is an odd size, requiring DOM.  (Drawn over mandrel,) which is seamless, and expensive.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 3:11pm
Yes, the "reach" as Electric Wheel Co referred to it, used same thickness as end frames(axles). Reach was engineered to bend before the end frames bent. If you over-engineer the thickness of its reach, look-out for end frame compromises.
