vbelt running with a twist
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: vbelt running with a twist
    Posted: 20 Sep 2016 at 10:33pm
what will run better on pulleys that run on a half twist- A section ,B section or 4l's, 5l's
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 10:56pm
hexagon belts
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 11:44pm
Originally posted by shameless (ne) shameless (ne) wrote:
hexagon belts
X2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 5:03am
hexagon belts would be classified as AA, BB, CC etc...
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 5:30am
I beg to differ with the Nebraska redneck but the hexagon belts are for arraignments that run on both sides of the belt and if run twisted they will flip easier than a standard belt due to less shoulder.   Most factory twisted belts run in deep groove pulleys. HP required determines what belt you use, twist has nothing to with it. If you can use an A belt use the pulleys that are machined for both A and B belts and they will work great. Dodge and Woods both make them.
Edited by Butch(OH) - 21 Sep 2016 at 7:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 6:21am
Belts that need to run twisted MUST be installed correctly as per the machines manufacturers instructions. Done any other way they will roll. AA, BB or CC belts are two belts made as one, side by side.  If you are constantly having problems a round belt may be you only hope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 7:45am
If I'm 'picturing' this right , you have a 'mule' drive so a HIGH QUALITY 5L will run very well ! Get a 'kevlar' belt, one DESIGNED for 'tight' corners..regular V-belts only like 'straight' runs between pulleys.
proper belt is 3-4X cost but will last a very long time !
This page was generated in 0.050 seconds.
