Valve Clearance
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Valve Clearance
    Posted: 11 Jan 2026 at 1:03pm
Working on my D14, replacing the valve cover and manifold gaskets. I am going to check the valve clearances and make any adjustments if necessary while I have the valve cover off. Since many components have been removed to prep for paint I can’t start the engine to get it to operational temperature as the manual recommends. Question is, is there a big difference checking them cold versus hot? .012” is what the book calls for. Obviously much easier to check them at this point with all the sheetmetal off, or should I wait until I put it back together to get it up to operational temperature?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 2:05pm
I always set them cold, and add about .002" to the hot spec. I've never felt I could go through them all quick enough hot to be the same temp from start to finish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 2:36pm
I agree with you ED, it wouldn’t be consistent on a hot engine by the time you went through them all. So you would set them at .014”? The book gives a range of .012”-.014”.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 2:40pm
Probably so. Intake lash usually tightens up over time, exh usually gets loose.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 3:04pm
I would set them cold at 0.014" and forget about it. Back in the day I set the valves on my 1955 Ford with the Y-block 272 hot and running. What a mess!
Son-in-law has a 53 F-350 with a 292 and I just adjusted them to zero clearance cold and then opened them up 1/4 turn. It works out the same Tongue
Edited by Les Kerf - 11 Jan 2026 at 3:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 4:39pm
The oily mess was my other concern Les. I’ve adjusted cold on my D17D and other tractors I have but just wanted to get some other opinions. I don’t recall adding any though which I understand why it’s suggested. Thanks to both of you.
Edited by AC720Man - 11 Jan 2026 at 4:42pm
Clayfoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clayfoot Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 5:56pm
Has anyone done a running lash adjustment on these, or do you get too much oil spray?
Edited by Clayfoot - 11 Jan 2026 at 5:56pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 8:15pm
With a .012 to.014 range l would go .002 over mid-range (.013) and set them at .015 cold.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 9:00pm
For some reason seems like valves get adjusted to tight on old tractors,with low RPM motors like in old tractors I've found a little loose is better than a little tight.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 6:03am
DrAllis suggested .015 cold several years ago. Since then, I have always used this setting. No problems, so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 6:25am
.015" COLD for intakes and exhausts on all West Allis built 4 cylinder engines. While some want to re-invent the method, this has worked for 50 years for me and is EASY to remember and do.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 6:58am
I've seen it done on V-8's with hydraulic lifters. I can not imagine trying to do it on a mechanical lifter cam.
I hate 'hot' valve lash specs. Like Ed said, who's fast enough to get them all set before the engine is cool? I recently set lash on my Farmall 450, they have a hot spec. So I added .002" and set them cold. Will check them after first run at head re-torquing time. Also put the head on the 756 gas yesterday, another hot spec. Will do same procedure as the 450.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 9:56am
I had a learning experience this morning I thought I would relate;
Reading the manual for the 756 where it talks about valve lash it has a footnote. It says, "engine warm means any temperature above 32 degrees F.". Well, that's a bit different than my thinking of warm! Guess I'll have another look at the 450 manual and see if it's the same. May be tightening them up a couple thousandth's.
I have no idea if Allis, or any of the other manufacturers for that matter, used this description.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 11:35am
I've seen it done on V-8's with hydraulic lifters. I can not imagine trying to do it on a mechanical lifter cam...
My late Father-in-law had a handful of old beat up feeler guages from his years as a service station mechanic back in 1950's-60's.
As I mentioned above, I have done it on old Fords in my youth but have since been enlightened Big smile
Edited by Les Kerf - 12 Jan 2026 at 11:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 2:31pm
When I see the valve lash specs, they usually say cold, as in ambient temp, or hot as in engine up to operating temp. I have never seen one give a spec for actual cold temps.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 4:14pm
I have always done valve sets at ambient temperature. Add .002 to the spec as all others have said!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 10:19pm
I set them at .014” today thinking the thread was done, checked at 8 am. Only 3 valves needed a slight adjustment.
Edited by AC720Man - 12 Jan 2026 at 10:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:44am
Should be good. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 24 minutes ago at 10:50pm
Cat book says cold.  .015 IN, .030 EX ....and give you plus or minus .003 on either side.  Yes, .006 variance saying if in that range it's ok.
Edited by SteveM C/IL - 10 hours 23 minutes ago at 10:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 10 minutes ago at 6:04am
That +/- .003" is interesting. I'm always wondering if I have the correct amount of 'drag' on the feeler gauge. How do you know when you're right?
Friend of mine called just after I set the valves on the 756, he was aware of the "warm means any temp. above 32" thing. Also got a comment on You Tube, the gentleman had set a 560 warm, (I think) and checked them cold and could find no difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 55 minutes ago at 8:19am
... I'm always wondering if I have the correct amount of 'drag' on the feeler gauge. How do you know when you're right?...
If you put just the end of the feeler gauge in the gap and can push (not pull) it in without the gauge buckling while feeling a slight drag, you are well within reasonable range. Don't sweat the petty stuff, it really isn't that critical.
A more likely issue is the fact that there may well be a significant notch worn on the rocker tip, there is no way possible to get accurate readings with a feeler gauge in this situation. The manufacturers specification naturally presupposes the parts to be in good condition.
I used a dial indicator to set the valve clearance on the old Model C that I call Mr. Cato's tractor; the rocker tips are heavily worn on that engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 52 minutes ago at 8:22am
I make sure I can still rotate the push rod while the feeler gauge is in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 40 minutes ago at 8:34am
The Detroit book says .015 hot. Says a .016 won't go and a .014 will be loose
