Vakve spring compressor tool,,,,,, |
Page 12> |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13752 |
Topic: Vakve spring compressor tool,,,,,,Posted: 21 Jun 2020 at 10:06am |
G' Mornin to all,,,it time to get up,,,,,,, ![]() I have what I think is a chinese valve spring compressor tool that flat refuses to compress the valve springs on this 454 I'm building. I struggled with this sob taking em off and made up my mind I'm gonna "nodify" this tool with a 24" cheater,,if I can figure out a way,,,, ![]() What I would really want is to modify the handle that you use to compress the spring to where the handle goes OVER the main frame of the tool,where you are compressing DOWN onto the tool,,,,? I remember using one built like that years ago and the amount of leverage was amazing!! All the ones built these days have the compression handle on the back with only about a 6" handle. The one I remember had a handle almost the same length as the whole tool length. I think it was a Craftsman but not sure. I googled Proto, Mac-tools, S&K, Snap-On and ain't fount what I'm lookin for,,,, Anybody got one that can post a pic for me,,?? Please,,,,,??
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5136 |
Posted: 21 Jun 2020 at 10:17am |
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 21 Jun 2020 at 10:29am |
john(MI)
Posted: 21 Jun 2020 at 11:44am |
We used to use two screwdrivers. One guy pushes down on the valve spring and someone else removes the keepers.
chaskaduo
Posted: 21 Jun 2020 at 11:54am |
Joe probably doesn't have another guy in his tool box.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 21 Jun 2020 at 2:04pm |
Good luck Joe, you're gonna PAY for a good one. I'm glad I've still got mine from back in the 60's. I don't even know who made it, but it is like you describe. I'll keep my eyes open at auctions this summer and fall for you.
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5153 |
Posted: 21 Jun 2020 at 2:43pm |
Maybe I'm just young and stupid but what are vakve springs??
chaskaduo
Posted: 21 Jun 2020 at 3:46pm |
An engine part on the USS Federation Enterprise NCC 1701.
Edited by chaskaduo - 21 Jun 2020 at 3:47pm |
thendrix
Posted: 21 Jun 2020 at 3:50pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5223 |
Posted: 21 Jun 2020 at 4:14pm |
Trick is to give all the retainers a light tap on a little angle before you try to remove them
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42170 |
Posted: 21 Jun 2020 at 8:08pm |
Was just thinking of when I replaced the valve seals on my 65 -Olds 400 engine in my 442 . Did it with a compressed air fitting into spark plug hole and a handle that fit over rocker stud , compress spring , remove keepers , remove the retainer plate on spring , then remove spring and install new valve seals , revers operation and move to next valve . All 16 done in about 2 hours time and didn't drop one valve into engine .
desertjoe
Posted: 21 Jun 2020 at 8:16pm |
Well,,I DID find one like I was talkin bout on the link ole Chask posted,,(Thet guy can find anything can't he?) and was able to find an OLD craftsman on Ebay but it is for bid and still has 3 days to complete. I also seen one listed as "HEAVY DUTY" that looks like a BIG glorified "C" clamp that just has a long all thread with a T handle to tighten up on the valve spring. Jeeeze,,all that engineering for only $242,,!! I might could modify one of my "C" clamps and drive the all thread with an impact,,,? I do not do any more major overhauls for people because of not having the proper tools,,,this outa teach me a lesson,,!! ![]() ![]() OH,, and Tyler that is "valve" ,,,,
kinda like the Prez's covfkee,,,,,![]() |
ocharry
Posted: 21 Jun 2020 at 9:59pm |
Hey Joe...I got a couple..you want me put them in a box and send them to ya??? You can try them out see what ya like...get the job done and when you are finished....send them back...hate to see an old gear head stuck....I will toss you a line and pull ya out😁😇
Ocharry |
desertjoe
Posted: 21 Jun 2020 at 11:20pm |
OCHARRY,,,You is just the greatest,,,and don't listen to what ole Shameless tells you,,,,sent you a PM so he don't know what we is discussin,,,,,
chaskaduo
Posted: 22 Jun 2020 at 7:43am |
Oil Can
ocharry
Posted: 22 Jun 2020 at 8:41am |
aaawwww shucks fellers
![]() ocharry
Joined: 11 Sep 2009 Location: illinois Points: 89825 |
Posted: 22 Jun 2020 at 9:08am |
I cut a "C" out of 1/4 inch plate and welded a nut on one end.. Got a 8 inch long 1/2 inch all thread for the adjuster and welded a handle on it.......... looks like a light duty C clamp.. been using that for 40 years.
ocharry
Posted: 22 Jun 2020 at 11:21am |
WHEEEEW WEEE,,,,dang i went out to git thet stuff ready to go,,,,no box,,,,,so i rapped it up in a feed sack,,,used some of my best masking tape and wrote this here is a goin to ol Joe down in NM,,,,didnt know we had us a state named thet but thets wher he said to send her so,,,,,then the car wont start,,,,so i gits on ol alice and she says NOPE I AINT A GOIN TO TOWN,,,welll what the heck has your panties all twisted,,,,,,,,,so i gits on the wheeler,,,it ran outa gas,,,,,so then i gits in the ranger,,,dang battery is dead,,,,,awwwww what the he,,,heck,,,so i jest went ta walkin,,,,cuzz i know ol joe is a needen me ta pull through fer him,,,,,and what do ya think,,,,it kuma rain like i aint never seen,,,good thing them feed sacks is plastic coated
so i gits to the post office and the lady is a yellin at me fer gittin her floor all wet,,,,now just hold on thar lady i says,,,,this here package is a going to ol joe over in NM and i bin bustin it ta git here afor ya close so can we mail this and git it on the way,,,,,well she finally shut up about the floor,,,and says,,," oh so your a payin customer" and then kinda giggles ,,,,what the hay,,,come on over here big boy,,,,,wow nelly then she turnt sour agin and said you cant mail that packaged up like that,,,,so i give her the ol sob story and told her it all i gots mam,,,bein al polite and all,,,finally she let it go i tell ya,,,and then you wont believe what happened on the way home,,,,,,dang if it didnt start a rainin agin,,,and then i got run off the road and went in a ditch,,,,tore a hole in my tenirunner ,,,,wheeew i am galed but,,, am i glad ta be home so there ya go joe,,,,stuff is in the wind yur pal ocharry ps ifin ya wants the trackin number i will PM it to ya,,,,dang thing must be 35 numbers,,,and this here number pad only goes up ta 9,,,,so i will give it a try ifin ya wants it,,,,, ![]() ocharry,,,,agin
Ted J
Posted: 22 Jun 2020 at 3:04pm |
Now that's about the tallest long tale I've heard in a while.
If'n ya didn't send em both to ole Joe, ya can send me one. I'd like to have a spare. I'll send it back when ole Joe tells me to. I never had any luck sending silver packages thru the mail and especially to Nude Mexico. Just sumthin about silver packages out there. They just get lost... |
HD6GTOM
Posted: 22 Jun 2020 at 3:53pm |
When I first saw that picture, I thought it was a wine bottle Corker. I been working on engines all me life and never saw 1 like that. Hoping ya finds a good 1.
chaskaduo
Posted: 22 Jun 2020 at 5:08pm |
Here's a song for ya Oil Can. [TUBE]PYIrs1Dx4Ck[/TUBE]
ocharry
Posted: 22 Jun 2020 at 7:11pm |
well fellers i wasa gona send sum missery rocks over to ol joe in thet box but i got ta figerin on it and i figered these missery rocks and them NM rocks might not git along,,,,so i didnt send any ,,,,,but i will ifin you wants sum joe,,,,gots plenty of um
i sent 3 differnt spring compresers ,,,,you can see what one wurks best fer ya joe,,,,i kinda like the one with the screw ,,,you will see how it wurks when ya gits it,,,its had a lot of RAT springs off ,,,,clamps on srew it down ,,,give it a little whack and poof,,,you will see now TEDDY that is pertnere ZACKLY how it happend ,,,,pertnere,,,i say,,,,aint now tall long winded stuff goin on thet is the purdiest song i ever heared ,,,,thanks much,,,it made the day and thats my story,,,,im stickin to it too ocharry
ocharry
Posted: 22 Jun 2020 at 7:24pm |
awwww i love at song,,,lol,,,,one of the great ones
play it agin sam!!!
ocharry |
desertjoe
Posted: 23 Jun 2020 at 3:33am |
"Oil Can",,,huh,,,??? HMMMmmmm thas a cute one,,,but I think I like Ocharry more better,,,won't nobody ever be able to copy that one,,,,,, ![]() ![]() And,,,and,,,I don't need no more rocks,,Thank you I gots a pretty good rock growin farm as it is,,,that and them dang Goat Heads,,,Ya wants some of them,,,,??? They is gauranteed to grow and multiply faster than diahrria,,,, ![]() I'll take good care of them tools,,,and if you don't want em back,,,I'll still take good care of em,,,,,,,,
desertjoe
Posted: 23 Jun 2020 at 3:35am |
Say,,,,,you gettin to be a pretty good story teller bout like me,,,ain't you,,,????
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34513 |
Posted: 23 Jun 2020 at 9:22am |
I just seen this and thought it was pretty neat... [TUBE]b1DmJQ4Fods[/TUBE]
ocharry
Posted: 23 Jun 2020 at 9:29am |
well i thank ya joe,,,but,,,nope you dont need ta be a sendin me no rocks neither,,,gots plenty of um ,,,,and fer sure no goat heads,,,,i think they is a migratin up thisa way any way,,,,i tilled one up the other day,,,i bet thet dang thing weighed 30 pond,,,,
STORY TELLIN,,,,,well i never,,,,you and TEDDY been talkin ahind my back,,thats kinda the same thing he said yestady,,,,,i mighta stretched it a mite,,,,just fer efect,,,,but i will rase my hand up,,,,not to high,,,maybe about to the bottom of my ear,,,,and tell ya that is how she happened ,,,fer the most part,,,,still typin so thats gotabe wort sumpin,,,no lightenin,,,yit any ways heck joe i knows ya will take good care of thet stuff or i wouldnta sent it over to ya,,,i aint worried none,,,,take yer time and when yer done send them home,,,,no worries,,,and fer sure no hurries,,,ahaahhahaa,,,i made a funny,,,i doubt i will be needin thet stuff anytime soon,,,,lol i am kinda gittin the feelin you fellers ait believin my account a what happined yestady,,,,hmmmm,,,,now i know the trip home was kinda short soundin,,,,i only just hylited thet thar ,,,,but i told the whole shebang about the trip over thar,,,,well pertnere ocharry Edited by ocharry - 23 Jun 2020 at 9:34am |
desertjoe
Posted: 26 Jun 2020 at 2:02am |
Well,,,I got home from the mountains kinda late yesterday and had a heavy package waitin for me on the porch,,,,,HMMmmmmm??? Opened her up and ,,,,and,,,I'ma tell you,,,ole Ocharry can go to work for the USPS, or UPS or Fed-Ex ,,,,he gots packagin Talents like I ain't ever seen before,,,,!!!! There was 3 separate tools and each item triple wrapped in good grade paper,,,( NO SEARS CATALOG PAPER HERE) ( OR WALMART SACKS) and then the whole shebang wrapped in still more paper,,!!! There just ain't NO WAY even some of ole Shameless's Tannerite sticks could'a opened this packagin up for no reason,,!!! ![]() Ole Ocharry,,he gots him a talent for sure,,,, UMMmmmmm, OCharry,,,I'll take good care of them for you,,,!!!!!
ocharry
Posted: 26 Jun 2020 at 11:42am |
awww shucks,,,wernt nuttin i tell ya,,
hey joe you gits your ol camper jacked up ok??? be careful ol pard,,,fur sure dont git hurt gittin her back up on them stands and leveled up take your time with that stuff joe,,,i know you gots lots to do ,,,i aint in no hurry,,,,git that big ol rat purrin,,,,with a big throaty growl,,,,heck kinda give me goose bumps thinkin about it,,,,lol,,,ahhhh,,, the good ol days,,,, sure hope one a them spring tools will work fur ya,,,im purdy sure one ofum will ocharry
desertjoe
Posted: 28 Jun 2020 at 4:27am |
Hey OCharry,, I finally got around to doin the valve springs on the RAT,,and I used the tool that clamps around the spring and just screw the big knob down and just pretty as you please compresses the spring to where installing the keepers is a snap,,,!!! Got all the intakes done in bout 30 minutes,,,,sure do Thank you, my friend,,![]() I was gonna look at buying one of those like I talked bout or modify mine but Now think I'm gonna get one like yours,,don't take near as much effort to replace the springs. I "thought" you might of expressed some interest in tradin the one tool for a bag of goat Heads,,,them be good medicine for that nasty neighbor that won't go away and,,,,SAY,,,!! I'll bet you can sell them Goat Head seeds to ole Shameless,,,he needs something for his stockholders flower beds,,,,,you Both can thank me later,,,,, ![]() I'm packagin them tools up now and will "slip" them seeds in thar,,,just don't let on where you got em from,,,,, ![]() Again,,Many Thanks, Guy,,,,,!!!
Page 12> |
