Update on 7060 PD Trans Issues
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Update on 7060 PD Trans Issues
    Posted: 11 Jul 2012 at 9:00pm
Well I changed the tranny filter and cleaned out the suction screen which wasn't very dirty.  I filled with fresh oil.  The old oil looked good on the dipstick, but when pouring out in the light it looked dirty.  I installed a pressure guage at the filter sending unit, and at idle it produced close to 30psi, and at high idle it produced over 60 psi.  The tractor is now functioning again.  The only issue it has is there is a hesitation for a few seconds when taking off in 5th gear, high range, low PD.  Is this normal, or do I have some upcoming PD issues??  Thanks so much for the help, Dr. Allis and MACK, along with others!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 9:18pm
On top of the Power Director valve there is a round plug that takes an allen wrench to remove. Remove this plug and use it to procure a fitting that will fit that hole and get a pressure gauge/hose and check the pressures at full throttle and hot oil....should be 195-205 psi.....by "hot" I mean in the field for an hour or drive it down the road for an hour at top speed. If pressures are acceptable, you may simply have a PD clutch that needs to be resealed and freshened up a bit.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 10:20pm
Could also have the torque limiter slipping when you take off in 5th.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2012 at 6:54am
Thanks, guys.  I will do that when I have a chance!  I had thought of the torque limiter as well.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2012 at 7:17am
Sounds to me like torque limiter also . My 7040 had hesitation  now and then .. fixed the torque limiter , problem solved ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2012 at 2:53pm
Thanks, Michael!
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2012 at 2:57pm
Kevin .. there are ways to fix it w o ....a full blown AC (AGCO ) REPAIR KIT .....
This page was generated in 0.508 seconds.
