Un styled wc ?s
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Un styled wc ?s
    Posted: 24 Feb 2012 at 2:01pm
Im wanting to order a steering wheel is the styled the same? Also mine has the 6 bolt wheels on the front what size tires would these be thanks.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 2:09pm
All the unstyled WC's ive seen have a flat spoked steering wheel styled have a round spoked wheel same as WD and WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 2:14pm
Mine appears to have the round spoke but ive been searching and havent found a new one listed for a un styled and my front tires are basically gone lol. Amazingly the front rims look nice though.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 2:56pm
Original front size was 5.50 X 16. on 6 bolt rims and same on 5 bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 3:10pm
Thanks one last ? How many gallons of gas does the tank hold i want to line it im guessing ill have to buy 2 of the cans since they only do a twelve gallon tank and im guessinng its a 15 gallon tank thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 3:13pm
You're right on that one.  Ref. book says 15 gallons for both styled and unstyled.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 5:16pm
I did a WD tank thats 15 gallons with a 12 gallon kit, worked just fine.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 6:27pm
Nobody makes reproduction flat spoked ones for the WC. There are ones out there that can be repaired to like new by  http://minnkotarepair.com/steeringwheel.html
Call around to guys that part tractors out and find an original. It cost $65 plus the ride to have one redone.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 7:10pm
Did even the unstyled '38s have a flat spoke just before the style change? Wondering if they did not.
Galatians 5:22-24
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 7:19pm
Don My unstyled 38 had covered round spokes and the center hub was coated. I've never seen another like it. I don't know for sure that it was original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 8:09pm
Im not even sure what year mine is i cant read the serial number so i just ordered the round spoked one im thinking i need to find a cheaper hobby lol. I almost have everything i need to get it done. I still need to figure out what im going to do with the rear tires i have steel wheels right now got the rims but there just about junk. But i've allways liked the unstyled wc's looks
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 8:18pm
I've got two 38s and both have a covered round spoke wheels.
Edited by Denis in MI - 24 Feb 2012 at 8:19pm
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 8:48pm
I have 2 flat spoke steering wheels for un styled WC. Would need to be redone>$75.00 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 7:32am
The only reason I am thinking they could have used round spoke, is because our family WC had spoke before a restore. It had been painted once since new, so It may have been replaced. But that was many years ago. Good chance that steering wheel in the picture came new on the tractor.
Edited by Don(MI) - 25 Feb 2012 at 7:33am
Galatians 5:22-24
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:20am
Measure the shaft size. The 33-34 had a larger shaft then those that followed. I have a covered one with the for the larger shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:20am
Don, What year is that one, 1938?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:25am
What diameter is the shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:55am
Charlie, yes its a 1938
Galatians 5:22-24
