Trying to identify year of tractor |
Page <12 |
Jemak1234
Posted: 15 Sep 2021 at 6:44am |
Jemak1234
Posted: 15 Sep 2021 at 6:46am |
Jemak1234
Posted: 15 Sep 2021 at 6:51am |
Based on the serial numbers on block and by shifter - can anyone tell me the age?
Posted: 15 Sep 2021 at 10:22am |
Based on the curved gearshift, it is either a later 1952 WD or as new as a 1957 WD-45. The serial number for the chassis is directly above the left side square headed bolt just above the rockshaft on the rear face of the rear end housing. It is stamped and will say WD XXXXXX. The number you have provided is a raised "casting" number and really means nothing to me. The serial number for the engine is also stamped and is directly behind the hose that runs from the air cleaner to the carburetor. It will say W-xxxxxx for a WD engine or 45-xxxxxx for a WD-45 engine. |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1589 |
Posted: 15 Sep 2021 at 2:24pm |
What happened to throttle quadrant?
JohnColo
Joined: 03 Apr 2020 Location: Niwot, CO Points: 1263 |
Posted: 15 Sep 2021 at 3:12pm |
The posts were from April of 2017 so I assume the tractor is long gone. He last was on the forum April 4, 2017. Must have found a home for the tractor.
Edited by JohnColo - 15 Sep 2021 at 3:14pm |
1951WDNWWI
Bronze Level Access
Joined: 11 Jul 2011 Location: NW Wisconsin Points: 124 |
Posted: 15 Sep 2021 at 5:46pm |
Tall head on a WD makes it a 1951 or newer if original.
Jemak1234
Posted: 15 Sep 2021 at 8:03pm |
The Block serial is WD 35448 4PA The 4PA is raised slightly from the others
Posted: 15 Sep 2021 at 8:13pm |
So, it's a late 1952 or up to mid 1953 WD. It is not a WD-45 unless you give me the chassis S/N.
Jemak1234
Posted: 16 Sep 2021 at 8:25pm |
I can barely see some of the serial number on the rear differential exactly where it was described to be, but there is too much paint to make it out. Any thoughts on best way to remove the paint without messing it up too much?
Jemak1234
Posted: 16 Sep 2021 at 8:28pm |
If anyone has a lead on some rear tires, I am need of 2 decent tires and I think I have 2 salvageable rims... but I'll have to see when I change them. I have a spare rim that is good with another bad tire on it. I have an extra bucket if someone needs one.
allisbred
Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Posted: 16 Sep 2021 at 8:44pm |
If the manufactured year of the rear is that important to you and have any access to a black light, wipe clean the area good with alcohol. The uncleaned depths in the stamping will become visible with the UV bulb in a very dark setting. Please remember that motor swaps were very common due to interchangeability for these tractors. End of the day— curved shifter indicates late wd though 45 time period trans. Tall head and no engine plate, most likely a 226, can be checked with wire in spark plug hole for stroke verification..
Edited by allisbred - 16 Sep 2021 at 8:46pm |
Mbressie
Posted: 26 May 2024 at 1:23pm |
I'm trying to date my tractor. The only numbers I'm seeing are WD 245030 and WD 40246.
dfwallis
Posted: 26 May 2024 at 2:48pm |
WD40246 is 1950
WD245030 is 1957 Edited by dfwallis - 26 May 2024 at 2:49pm |
1952 CA13092
Page <12 |
