8050
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 8050
    Posted: 28 Aug 2014 at 9:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 9:39am
My 8050 makes a noise in the hyd when the 3 point hitch lever is all the way up with the mower is raised. If I move the lever down a little it quits. Sounds like it is against a relief valve. I am going to put a gauge in the system to check stand by pressure later today. Any ideas what it could be?
Thanks, Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 4:50pm
Adjust/lengthen the cable to the 3-point valve. It should NOT come 100% to the top....only 99%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2014 at 9:18pm
Thanks, I will try that. Once again Thanks
