6080 hyd dipstick ? |
Post Reply ![]() |
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Aug 2014 at 5:21pm |
on our 6080 the dipstick for the hyd/ rear-end wont fit, it looks like there should be a insert or something to make the hole smaller ,I have the correct dipstick but it is too small, I was looking on AGCO PARTS and it listed part #75127439 with the dipstick but there was no pic. or description of that part, any help would be appreciated. THANKS TOM.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
JIMncMO ![]() Bronze Level ![]() Joined: 06 Dec 2009 Points: 46 |
In the earlier 6080's the dipstick threaded into the housing. On some of the newer ones they welded a piece of pipe on top of the housing and the dipstick just slid in it. Sound like you may have an early dipstick, and a later model tractor.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21903 |
Look one up for a 6070 tractor and see what it is. I'm trying to figure out why you are changing a dipstick.........did you lose the original??
bump
6070 dipstick is 72094258...............6080 dipstick is 72094231.........
G3farms ![]() Bronze Level ![]() Joined: 19 Sep 2009 Location: Knoxville, TN Points: 23 |
I have one of the very last 6080 to be made and they had the small thread in dip stick. The pto housing broke and I had to buy a new one ($1,500), the new housing has a much larger threaded hole for the dip stick plus two extra holes in the left side. This housing is also interchangeable with one from a White I am thinking a 6000 series.
I think the larger threaded plug is 32 mm I just put an expandable rubber plug in mine and use the old dip stick to check level. Be extra careful not to drop it into the pto housing. |
Proud owner of one of the very last 6080 tractors, serial no. 7711, yep it is correct!
Post Reply ![]() |
